ZABBIX Forums
Old 07-02-2014, 04:43
desmondho desmondho is offline
Exclamation Zabbix Trapper Memeory Leak
Dear all,
Here is my Zabbix environment details:
Version: Zabbix-server 2.2.1
Number of Hosts: 338
Number of Items: 5162
Distributed with totally 4 nodes
My Zabbix server is having a serious memory leak problem as attached.Name:  mem.jpg
And it seems the Zabbix Trapper process holding the memory and will not release until restart the zabbix-server.
Attachment 6650
I would like to know if anyone have a solution or countering this problem
Sorry for my bad English and thanks a lot~!
Best regards,
Desmond Ho
Old 10-02-2014, 11:02
Default
After days of investigating, i found the RAM was consumed by the events update from distributing nodes.
I fixed it by enable NodeNoEvents=1 on all child nodes.
It would be appreciate if Zabbix Team found the root cause and fix it.
Reply
Tags
memory leak, trapper, zabbix 2.2.1
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
