ZABBIX Forums
Old 15-05-2008, 16:51
Jes Jes is offline
Default zabbix 1.5.2 source Not found mysqlclient library
hello,
I am trying to compile zabbix 1.5.2 in FEDORA core 6, and i ve got this message.
# ./configure --enable-server  --with-mysql
checking for mysql_config... /usr/lib/mysql/mysql_config
checking for main in -lmysqlclient ... no
configure: error: Not found mysqlclient library
i ve have seen all the tread in this forum about this!
i have put the path to libmysqlclient.so (--with-mysql=/usr/lib/mysql) => Not good
i have all the mysql rpm needed
# rpm -qa |grep -i mysql
mysqlclient14-4.1.14-4.2.1
perl-DBD-MySQL-3.0007-1.fc6
mysql-connector-odbc-3.51.12-2.2
php-mysql-5.1.6-3.7.fc6
mysqlclient10-3.23.58-9.2.1
MySQL-python-1.2.1-1
mysqlclient14-devel-4.1.14-4.2.1
mysql-5.0.27-1.fc6
mysql-server-5.0.27-1.fc6
mysqlclient10-devel-3.23.58-9.2.1
libdbi-dbd-mysql-0.8.1a-1.2.2
and now i am trying to compile mysql (with source) ...
keep in touch
any help will be appreciate
thank
Old 15-05-2008, 19:06
Jes Jes is offline
Default
I have compile mysql 5.0 , put the good path in --with-mysql and I've got the same problem
Need your help plz
Old 16-05-2008, 11:11
Jes Jes is offline
Thumbs up Yessssss
it works
without the compiled mysql.
just use the mysql in package BUT i had the mysql-devel with yum
# yum install mysql-devel
if you need more information, don't hesitate
Old 24-08-2008, 05:41
MacRonin MacRonin is offline
Default
Quote:
Originally Posted by Jes View Post
it works
The install of mysql-devel fixed it for me also.
Now onto my next stumbling block
Old 28-06-2010, 04:20
is36 is36 is offline
Default
good I have tried it,it worked.
My OS is centos 5.x
YUM is a good tool
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
