Announcement
No announcement yet.
Manual action
  • Filter
    Manual action
    Is there a way to perform a manual action instead of an automatic perform by a trigger status modification ?
    Starting from ZABBIX 1.6 you may use custom scripts to execute some action for a selected host. Note that the script will be executed on ZABBIX server side.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
      My need is to execute manually a script for a trigger or an event.
        Any idea ?
          Could you please provide some additional information on the topic?
          For example, how can I manualy (not by any triger or event) restart apache on remote host using zabbix agent ?
            As to the topic starter, I also wondering is it possible to manually run action.
            Eg, I define action, which restart specific host in case of trigger has being flagged. This action works fine, but, in addition, I need ability to manually run action, for the test purposes and to provide duty administrator ability to perform remote side reboot without giving remote shell for him. Is it possible? Also, I wondering is it any way to put such manual action run button (or something) on the network map? As ideal, I wish I could see host and common control buttons behind the host (eg. restart host, restart service,...) on network map.
