"Item became supported" log entries
  • Filter
    does anyone have any idea what might be going on here? I'm seeing intermittent log entries on the server such as:
    24484:20110530:001905.515 Item [Test NginxB:check_nginx.sh] became supported
    24471:20110530:002609.441 Item [Test NginxA:check_nginx.sh] is not supported
    24486:20110530:002847.208 Item [Test NginxA:check_nginx.sh] became supported
    24471:20110530:003612.372 Item [Test NginxB:check_nginx.sh] is not supported
    24486:20110530:004920.570 Item [Test NginxB:check_nginx.sh] became supported
    The check_nginx.sh is an external script that performs a simple curl to check that an SSL nginx server is up. I seem to be seeing a set of log entries like the above, then they disappear for a while. As far as I can tell the script is actually working fine.
    thanks
    Mike
Announcement
No announcement yet.
