Help to configure User Parameter
  • Filter
    I try to use UserParameter in order to monitor some host.
    The UserParameter will execute a shell script and return a value. I wrote this following sentence in the host's zabbix_agentd.conf :
    "UserParameter=check_glsa,/etc/zabbix/externalscripts/check_glsa"
    I already put the script in the good directory with the right permission.
    I configure an Item on the Zabbix server like this :
    Host : Template_Linux_myHost (my host is in this template)
    Description : GLSA
    Type : Zabbix Agent (Active)
    key : check_glsa
    I didn't have real error, however the value returned is bad, indeed in "latest data" the value GLSA is different that when a execute the script in my host. It's the value of my Zabbix Server..
    Plz someone can help me to resolve the problem..
    Regards,
    same
    I have the same error, did you fixed it?
      Yes i resolv it, but i forgotten the issue, maybe can i help you.
      What is your configuration ?
        size directory
        I set this on /zabbix/zabbix_agentd.conf
        UserParameter=test,du /home/aner/Desktop/test/ -cbxs | grep total | cut -f1
        When i do the command zabbix_agentd -p show me this
        test [t|29368637],
        but when i se it to zabbix item show me on lastest data value 0, and the file size is 29368637, so is not showing me correct data. Everyfile a try to get their size, showme 0
          asantana:
          There are a few things that you should check/do.
          If your zabbix agent is running under the zabbix user, then you should ensure that the zabbix user has privileges to use `du` and that it can access that folder. Like I had issues with the Zabbix agent being unable to run `lsof -p <process id>`due to permissions.
          Secondly, it is best if you can use an absolute path for `du`, eg. `/usr/bin/du`.
          To find the absolute path for `du`, run `which du`.
          To simply check if zabbix user can run that command, run the following:
          su zabbix -c 'du /home/aner/Desktop/test/ -cbxs | grep total | cut -f1'
          Like my zabbix_agentd.conf would look like this:
          UserParameter=test,/usr/bin/du /usr/src/zabbix-1.8.13/ -cbxs | grep total | cut -f1
          As a last resort, you can look for errors in your Zabbix server logfile.
          Announcement
          No announcement yet.
