Announcement
No announcement yet.
Extreme x430 Issue
  • Filter
    Extreme x430 Issue
    Hello, i need some help to solve a problema with the item key name.
    I want to put in the link the traffic of a port of Summit Extreme x430 48ports. But the item has the key "ifInOctets[X430-48t Port 48]". As you can see, has somes spaces in the name and i think that is why is not working. Only shows unknow. Someone can help me?
    One Time, I get the same problem..
    I don't know why but a stupid network devices also added a white space at the end of the interface name.
    eg : "ifInOctets[X430-48t Port 48 ]"
    You should verify it with a snmpwalk/snmpget
      Solved
      That's the thing, but it was a mistake of mine. I was putting the {HOSTNAME}, when i put the name of the host indeed, it's worked.
      But thank you a lot.
