Upgrade Zabbix from 3.2.7 to 3.4
  • Filter
    Hi all ,
    I am using zabbix and I decided to upgrade rpm package from 3.2.7 to 3.4
    I am trying to use rpm -upgrade zabbix , but it is not working
    i aslo try to install zabbix-release-3.4-1.el7.centos.noarch.rpm to upgrade repositey but I recive error :
    file /etc/yum.repos.d/zabbix.repo from install of zabbix-release-3.4-1.el7.centos.noarch conflicts with file from package zabbix-release-3.2-1.el7.noarch
    can anyone help me to update ?
    Please try update instead of install.
    # yum update zabbix-release-3.4-1.el7.centos.noarch.rpm
    # yum clean all
      Originally posted by omid1979 View Post
      Hi all ,
      So what exactly is not working?
        Thanks for your answer ,
        I do the flowing steps and now upgrade to Zabbix 3.4
        PHP Code:
        yum update http://repo.zabbix.com/......zabbix-release-3.4-1.el7.centos.noarch.rpm
        yum update zabbix-agent
        yum update zabbix
        -web
        yum update zabbix
        -server-mysql
        yum update zabbix
        -sender
        yum update zabbix
        -get
        yum update zabbix
        -java-gateway
        yum update zabbix
        -release-3.2-1.el7.noarch.rpm
        systemctl restart zabbix
        -server
        Thanks so much ,
          I've followed that but it's just not doing any database upgrade i just get the "The frontend does not match Zabbix database. Current database version (mandatory/optional): 3020000/3020000. Required mandatory version: 3040000. Contact your system administrator."
          The logs are not saying it's doing the upgrade.
            This could take some time. What exactly logs are showing to you?
            Regards,
            Alex!
              11543:20170929:102211.405 syncing trend data done
              11543:20170929:102211.405 Zabbix Server stopped. Zabbix 3.2.2 (revision 64245).
              12400:20170929:102222.320 Starting Zabbix Server. Zabbix 3.2.2 (revision 64245).
              12400:20170929:102222.320 ****** Enabled features ******
              12400:20170929:102222.320 SNMP monitoring: YES
              12400:20170929:102222.320 IPMI monitoring: NO
              12400:20170929:102222.320 Web monitoring: YES
              12400:20170929:102222.320 VMware monitoring: YES
              12400:20170929:102222.320 SMTP authentication: YES
              12400:20170929:102222.321 Jabber notifications: NO
              12400:20170929:102222.321 Ez Texting notifications: YES
              12400:20170929:102222.321 ODBC: NO
              12400:20170929:102222.321 SSH2 support: NO
              12400:20170929:102222.321 IPv6 support: YES
              12400:20170929:102222.321 TLS support: NO
              12400:20170929:102222.321 ******************************
              12400:20170929:102222.321 using configuration file: /usr/local/etc/zabbix_server.conf
              12400:20170929:102222.330 current database version (mandatory/optional): 03020000/03020000
              12400:20170929:102222.330 required mandatory version: 03020000
              12400:20170929:102223.460 server #0 started [main process]
              12405:20170929:102223.461 server #1 started [configuration syncer #1]
              12406:20170929:102223.461 server #2 started [db watchdog #1]
              so on my centos i've done the yum update on all the bits and its showing i've got 3.4 installed so bit unsure why this is staying at 3.2
                Hi AlexYoung,
                The package of 3.4 is already installed, is not it?
                Please check if you installed version installed from source.
                Announcement
                No announcement yet.
