[ERROR] unable to find mysql.h
  • Filter
    When I did try to install ZABBIX 1.0 (the stable release) I did got the error shown below:
    checking for MySQL support... no
    configure: error: Invalid MySQL directory - unable to find mysql.h
    server2:/home/quicki/public_html/zabbix-1.0#
    OS: Debian 3.1 (net install)
    Control panel: DirectAdmin
    Other sites work fine with MySQL
    Could anybody tell me how I can solve this problem?
    Note:
    Reinstalling PHP or MySQL is not an option.
    you need the mysql development files installed.
    if they are, and it still cant find it, run ./configure --help and look for how to point it at the right directory.
      Where can I find if I have the development files installed?
        I'm not really a debian guy but I believe you can use the "apt" utility to query your packages
          Like I did say before:
          Note:
          The reason is that the server is also used for webhosting.
            nobody said to reinstall php or mysql.
            I said you need the dev libraries
            you asked how to look for them, I told you to use apt. what's the issue?
              Indeed, just type:
              apt-get install mysql-devel
              and you'll get the required files.
              Announcement
              No announcement yet.
