Announcement
No announcement yet.
Zabbix 2.2.0+VMware: Error returned by expat parser: not well-formed (invalid token)
  • Filter
    Hi folks,
    I've been using Zabbix for 6 months now, I was able to install it from the official repository on Debian 7 through its default package management system (apt), according to the official documentation, and so far, it been an awesome monitoring tool.
    Today I updated it to its latest version (2.2.0) in order to try out the new VMware monitoring, once again, I used the official pre-compiled package according to the documentation and apparently it worked well, as you can see below:
    6898:20131210:225806.600 Starting Zabbix Server. Zabbix 2.2.0 (revision 40163).
    6898:20131210:225806.600 ****** Enabled features ******
    6898:20131210:225806.600 SNMP monitoring: YES
    6898:20131210:225806.600 IPMI monitoring: YES
    6898:20131210:225806.600 WEB monitoring: YES
    6898:20131210:225806.600 VMware monitoring: YES
    6898:20131210:225806.600 Jabber notifications: YES
    6898:20131210:225806.600 Ez Texting notifications: YES
    6898:20131210:225806.600 ODBC: YES
    6898:20131210:225806.600 SSH2 support: YES
    6898:20131210:225806.600 IPv6 support: YES
    6898:20131210:225806.600 ******************************
    6898:20131210:225806.600 using configuration file: /etc/zabbix/zabbix_server.conf
    6898:20131210:225806.605 current database version (mandatory/optional): 02020000/02020000
    6898:20131210:225806.605 required mandatory version: 02020000
    I also manually imported the official VMware .xml templates, which also seemed to work.
    My configuration file (regarding the VMware settings) is the following:
    ### Option: StartVMwareCollectors
    # Number of pre-forked vmware collector instances.
    # Mandatory: no
    # Range: 0-250
    # Default:
    StartVMwareCollectors=10
    ### Option: VMwareFrequency
    # How often Zabbix will connect to VMware service to obtain a new data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    VMwareFrequency=30
    ### Option: VMwareCacheSize
    # Size of VMware cache, in bytes.
    # Shared memory size for storing VMware data.
    # Only used if VMware collectors are started.
    # Mandatory: no
    # Range: 256K-2G
    # Default:
    VMwareCacheSize=8M
    Finally I created all the necessary macros (on the host where I'm going to apply the templates), according to the documentation:
    {$PASSWORD} -> my_secret_password
    {$URL} -> https://vcenter.mynetwork.com/sdk
    {$USERNAME} -> my_zabbix_read_only_user
    And here's the issue:
    After 60 seconds all my Items get "Not Supported", followed by:
    while parsing serialized value of type string
    at line 1, colum
    The /var/log/zabbix/zabbix_server.log shows me the exhibit:
    6927:20131210:233442.516 item [vCenter-homolog:vmware.hv.hw.cpu.num[{$URL},{HOST.HOST}]] became not supported:
    at line 1, colum
    Any ideas about what might be causing this problem?
    That is exactly what happened to me.
    Does anyone have any idea what cause this problem?
      I'm getting same error.
      If you fix it, please, post the solution.
        The solution
        same trouble with esxi 5.1, vcenter on win2K8r2, zabbix 2.2.4.
        The mesage : Error returned by expat parser: not well-formed (invalid token)
        The using password for the esxi access have a & caracter, I have modified the password without special caracter and it's works.
        Ask questions to Zabbix Dev Team in person at the Zabbix Summit 2018!
