ICMPPING not supported
  • Filter
    Dear Zabbix Support,
    i'm using zabbix 2.2 and when i am adding icmp template for checking icmp ping its showing me not supported in status.
    please help
    Zabbix
    Are you using Zabbix Appliance version?
      ICMP not supported
      i am using zabbix 2.2 vhd file from hyper-v and i also ran fping as root , also uninstalled and installed fping but still not working.
        I had same issue.
        Correct permissions/ownership to:
        -rwsr-sr-x 1 root zabbix 31400 Jan 31 2013 /usr/sbin/fping
        -rwsr-sr-x 1 root zabbix 31408 Jan 31 2013 /usr/sbin/fping6
          Make sure it is not a SELinux issue.
          https://www.zabbix.org/wiki/InstallO...n_selinux_rule
            Icmp ping
            thanks its working now after ran below command..
            chown root.root -v /usr/bin/fping
            chmod a+s -v /usr/bin/fping*
            chmod -v 6755 /usr/bin/fping
              Yes, it was described in manual
              https://www.zabbix.com/documentation...?s[]=fping
              5.3 ICMP pings
              Zabbix uses external utility fping for processing of ICMP pings.
              The utility is not part of Zabbix distribution and has to be additionally installed. If the utility is missing, has wrong permissions or its location does not match the location set in the Zabbix server configuration file ('FpingLocation' parameter), ICMP pings (icmpping, icmppingloss, icmppingsec) will not be processed.
              fping must be executable by the user Zabbix daemons run as and setuid root. Run these commands as user root in order to set up correct permissions:
              shell> chown root:zabbix /usr/sbin/fping
              shell> chmod 4710 /usr/sbin/fping
              Sincerely yours,
              Aleksey
                please help
                in my case, SELinux (CentOS 6.5) was blocking fping after setting the right permissions. This was the solution: https://support.zabbix.com/browse/ZBX-760
                Also, icmpping can only run from the Zabbix Server, not from agents in other machines. I think the ability to create an item in a host that doesn't have the Zabbix Server template assigned is a bug...
                hope it helps.
                Announcement
                No announcement yet.
