Announcement
No announcement yet.
IP Address Change
  • Filter
    IP Address Change
    We installed a new PDC here and changed our IP addressing scheme and now I can't reach the Zabbix server for some reason. The login screen comes up, but when I try and login you can see on the status bar it's looking for the old IP address. I don't really have a whole lot of time to be scouring that server trying to figure out what the issue is, so I would really appreciate some help.
    make sure that the network setting on your server are Okay and check your http setting for the ip he listen to.
      It has a static IP, which is fine, and the apache settings appear correct. I don't know where it's pulling that old IP from.
        So what else can I check?
