Make Install on 64bit errors out.
  • droche7
    • Sep 2006
    • 13
    Here is some of my make output. Can someone tell me what I am missing? I have updated the /etc/ld.so.conf file with /usr/lib64/mysql/. Not sure what is going on
    make[5]: Nothing to be done for `install-data-am'.
    make[5]: Leaving directory `/var/www/html/zabbix/src/zabbix_server/trapper'
    make[4]: Leaving directory `/var/www/html/zabbix/src/zabbix_server/trapper'
    make[3]: Leaving directory `/var/www/html/zabbix/src/zabbix_server/trapper'
    make[3]: Entering directory `/var/www/html/zabbix/src/zabbix_server'
    gcc -g -O2 -o zabbix_server -L/usr/lib/mysql -L/usr/lib evalfunc.o expression.o actions.o zlog.o functions.o server.o ../libs/zbxsysinfo/libzbxsysinfo.a ../libs/zbxsysinfo/linux/libzbxsysinfo2.a ../libs/zbxlog/libzbxlog.a ../libs/zbxpid/libzbxpid.a ../libs/zbxconf/libzbxconf.a ../libs/zbxcrypto/libzbxcrypto.a ../libs/zbxnet/libzbxnet.a pinger/libzbxpinger.a poller/libzbxpoller.a housekeeper/libzbxhousekeeper.a alerter/libzbxalerter.a timer/libzbxtimer.a trapper/libzbxtrapper.a ../libs/zbxemail/libzbxemail.a ../libs/zbxsms/libzbxsms.a ../libs/zbxdbhigh/libzbxdbhigh.a ../libs/zbxcommon/libzbxcommon.a -lmysqlclient -lm -lz -lnetsnmp -lcrypto -lresolv -lnsl
    /usr/bin/ld: cannot find -lmysqlclient
    collect2: ld returned 1 exit status
    make[3]: *** [zabbix_server] Error 1
    make[3]: Leaving directory `/var/www/html/zabbix/src/zabbix_server'
    make[2]: *** [install-recursive] Error 1
    make[2]: Leaving directory `/var/www/html/zabbix/src/zabbix_server'
    make[1]: *** [install-recursive] Error 1
    make[1]: Leaving directory `/var/www/html/zabbix/src'
    make: *** [install-recursive] Error 1
  • sauron
    • Jan 2005
    • 215
    You install mysqlclient?
    PS I'm build zabbix on sparc64. It's run. But how it's work i'm not tested.
    • droche7
      • Sep 2006
      • 13
      Yes I have the mysqlclient installed. See Below. Any other Ideas with this?
      rpm -qa mysql*
      mysqlclient10-3.23.58-4.RHEL4.1
      mysql-4.1.20-1.RHEL4.1
      mysql-server-4.1.20-1.RHEL4.1
      mysql-devel-4.1.20-1.RHEL4.1
      mysql-bench-4.1.20-1.RHEL4.1
      mysqlclient10-devel-3.23.58-4.RHEL4.1
