Get value from agent failed. Error: ZBX_TCP_READ() failed [Interrupted system call]
  • rodelapena
    • Mar 2007
    • 22
    im getting this message on my server log
    the agentd doesnt report status and the client machine is loaded with agentd processes
    server and agentd are 1.4
    server is a RHEL ES 4
    agentd is a centos 4.0
    does anyone has this same problem??
  • gimpel
    • May 2007
    • 9
    I had absolutely the same problem with the agent running on my OpenWrt router and my Gentoo system, where I test 1.4 before I'm going to re-test it in our company (we gave up with 1.3 series)
    The problem was that I had set StartAgents=1 in zabbix_agentd.conf. Setting it to 3 and restarting the agents solved it.
    And iirc polling by DNS name also did not work correctly.
    • rodelapena
      • Mar 2007
      • 22
      i have 5 StartAgents, and tried polling fom dns and ip. i even update to centos 4.5 but the same error apears in my server logs.
      • gimpel
        • May 2007
        • 9
        I compiled the server and agent today on RHEL4up4 and installed the agents on 6 RHEL4 machines. No problems at all.
        Did you bind the agents to a certain IP address?
        Maybe just post your config(s).
        • rodelapena
          • Mar 2007
          • 22
          Server and Hostname goes to a fqdn of my server and agentd
          DebugLevel=3
          • dfavero
            • Dec 2008
            Hello my friends,
            This message on my server log
            The agentd doesnt report status and closed the client machine is loaded with agentd processes
            server and agentd are 1.4.2 / Debian Linux / Database postgresql-8.1
            zabbix_agentd.conf
            StartAgents=5
            DebugLevel=3
            Thank“s
            • martin.marcher
              • Nov 2007
              • 22
              Yes I have the same Problem.
              Let's create a canonical Thread here: http://www.zabbix.com/forum/showthre...0908#post40908
              I think this will help the Zabbix devs a bit. So that can at least go to a single place and ask for more debug info until this problem is solved...
              • prote
                • Dec 2008
                • 16
                Same error occured in my first Zabbix-installation last month. I had reduced the StartAgents to 2 cause I thougth, that 2 Agents will be enough. But that's not right, my Debian Lenny with Zabbix 1.6.1 needed 5 Agents.
                • Kai-Kai
                  • Apr 2009
                  • 142
                  I've had the same problem.
                  The solution was to set the correct dns name in the config file of the client (it wasn't the good one).
                  Server=<DNS name of the server>
                  And it solved the problem... I don't know if it can help for the future...
                  • par
                    • Nov 2006
                    • 21
                    Raising timeout in zabbix_server.conf helped me solve this issue.
                    • dantony79
                      • Aug 2010
                      • 12
                      get value from agent failed ZBX_TCP_READ() failed connection reset by peer
                      i have problems on 2 windows servers using win32 zabbix agents.
                      CPU utilisation Graphs goes broken and finally dies few minutes after starting zabbix agent.
                      Is there a permanent fix for this.
                      zabbix server version is 1.8.1
