Dear all,
as there was no rpm package for AIX 6.1 version. Here it is
in file zabbix-agent-aix.6.1.tar.gz everything is packed so you can use
included zabbix.spec to rebuild it if you like or just install it with
rpm -Uvh zabbix-agent-1.6.2-1.aix6.1.ppc.rpm
Notes:
will add /bin/false to /etc/security/login.cfg
will add group zabbix
will add user zabbix with primary group zabbix
and files/folders mentioned bellow (rpm output)
on uninstall will NOT be removed shell /bin/false from /etc/security/login.cfg
as it should be there anyway
MD5 sum of files
used compiler:
Notes:
MD5 sum of files
abb0046adc9d6fc0c1272ed73fbad71a rpm_buil_zabbix_agents.txt 69517f689494d9b6fe293246bc443f4e zabbix-agent-1.6.2-1.aix6.1.ppc.rpm 9ef472b7eed486048b59ff8c3b02f105 zabbix-agent-aix.6.1.tar.gz 53bb8c2854f042400162bd907da0e44c zabbix.spec
# oslevel -r 6100-00
IBM XL C/C++ Enterprise Edition for AIX, V9.0.
rpm -qlp zabbix-agent-1.6.2-1.aix6.1.ppc.rpm /etc/zabbix/zabbix_agent.conf /etc/zabbix/zabbix_agentd.conf /opt/freeware/zabbix/sbin/zabbix_agent /opt/freeware/zabbix/sbin/zabbix_agentd /var/log/zabbix /var/run/zabbix
