Blank web install
  • max
    • Jan 2008
    • 36
    Blank web install
    I've installed Zabbix 1.4.4 (server side) on RHEL4 with Oracle database. I've followed the steps in the manuel (see 3.4.3).
    I already have an Apache (with PHP 4.3.9) running under root on which I have configured the httpd.conf adding :
    Alias /zabbix/ "/path/to/install/folder/frontends/php"
    But when I try to access http://localhost/zabbix/ I've got a blank page.
    I tryed to add a page "phpinfo.php" in the php in frontends/php and it works when I test http://localhost/zabbix/phpinfo.php so it doesn't seem apache to be guilty of that.
    Did I missed something during the zabbix install ?
    ...need help...
  • Kees Jan Koster
    • Oct 2007
    • 83
    Any errors in Apache's loge file?
    • max
      • Jan 2008
      • 36
      PHP Parse error: parse error, unexpected T_STATIC, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /u02/zabbix/web/include/copt.lib.php on line 112
      Is it a problem with PHP version : maybe PHP5 is requiered... ?
      • xs-
        • Dec 2007
        • 393
        Edit includes/copt.inc.php
        Search for all occurances of 'static function' and remove 'static'.
        For example:
        Change
        /* protected */ static function getmicrotime() {
        To
        /* protected */ function getmicrotime() {
        There are several of these, so get them all.
        php4 doesnt understand 'static function functioname();'
        • max
          • Jan 2008
          • 36
          Great, it works !
          Thank you xs- and Kees Jan Koster !
          Fast answers besides
