Zabbix 1.1.2 on CentOS 4.4
  • agehring
    • Oct 2006
    • 49
    Zabbix is reporting the inetd is NOT running.
    it is.. at least xinetd
    Know problem?
    Resolution?
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    Not really a bug. The Zabbix Agent(d) is checking for the for a running process called inetd, which is the traditional name for the inet super server, not xinetd, which is a redhatism.
    Unofficial Zabbix Developer
    • agehring
      • Oct 2006
      • 49
      Is there a "work around'?
      • James Wells
        • Jun 2005
        • 664
        The best work around at present is to create an item with the key proc.num[xinetd] and for the trigger use {HOSTroc.num[xinetd].last(0)}#1
        • agehring
          • Oct 2006
          • 49
          Thanks for you help.
          Before I saw your reply, I modified the linux.c and unknown.c in /src/libs/zbxsysinfo directory to include the following:
          {"proc.num", CF_USEUPARAM, PROC_NUM, 0, "xinetd,,,"},
          {"proc.mem", CF_USEUPARAM, PROC_MEMORY, 0, "xinetd,,"},
          Recompiled, then added a item and a trigger identical to inetd, and disabled inetd for that host.
          Is it nessecary to modify the linux.c?
          it works, but I'm wondering if the C mods are nessecary (maintaing code and all of that)
          • James Wells
            • Jun 2005
            • 664
            These changes, basically only affect the pretend mode for the Zabbix Agent(d). This is when you are running the agent with the -p argument. With your change, it will show the correct information for xinetd while running in pretend mode, but doesn't really affect anything else.
