Windows UserParameter wildcards extension
  • jlh
    • Nov 2006
    As I was not able to use a UserParameter tag with[*] in Zabbix Win32 agent, I made some changes in the source code in order to support it. So with this version, you can define a line like
    UserParameter=Disk.FragLevel[*],c:\windows\system32\defrag.exe -a $1
    in you Win32 agent, and define an item with Disk.FragLevel[c:] in your zabbix server.
    Source file and compiled files are attached
  • navtek007
    • May 2005
    • 100
    great, any chance on getting this compiled for 1.1.5?
    thanks.
    • den_crane
      • Feb 2006
      • 272
      It's work!!!
      Thanks so much for posting this.
      • djinn_fr22
        • Jan 2007
        • 54
        I tried with agent 1.1.6, it doesn't work so it means that the patch has not been added yet.
        I tried the binary from jlh patch.
        It works when I test in local mode, but it doesn't work when I tried to get data from the zabbix server. I am running the agent in standalone mode and not as a service.
        I am going to try to compile it myself to see if there is a difference.
        • jlh
          • Nov 2006
          I have made one new modification this weekend: compile with 1.1.7 source and add an optional "nowait" tag at the end of the line with the command, this to allow long scripts.
          You can now have something like
          UserParameter=Test[*],TimeConsumingScript $1 $2 $3,nowait
          UserParameter=TestResult[*],QuickResultScript $1 $2 $3
          => The nowait tag will fork the script without waiting for the result. So if the script writes the result in a file, you just need to write another script that will quickly read that file.
          • jlh
            • Nov 2006
            Sorry: previous post has an awful bug. Here is the fixed version. I named this agent version 1.1.7.2. I also removed the incorrect attachment from the previous post.
            • den_crane
              • Feb 2006
              • 272
              Strange problem with:
              Zabbix Win32 Agent Version 1.1.4 Build of Dec 29 2006
              In temp dir (c:\winnt\temp) agent leave thousands small files.
              One host had 65k files, and agent stops.
              >dir /w
              Volume in drive C has no label.
              Volume Serial Number is 3865-5B42
              Directory of C:\WINDOWS\Temp
              [.] [..] 111 zbx1.tmp zbx1002.tmp
              zbx100A.tmp zbx1020.tmp zbx109E.tmp zbx10AF.tmp zbx10C9.tmp
              zbx10EB.tmp zbx10F6.tmp zbx115.tmp zbx117C.tmp zbx118B.tmp
              zbx118F.tmp zbx11B6.tmp zbx11E2.tmp zbx11E3.tmp zbx11E6.tmp
              zbx11E8.tmp zbx121.tmp zbx121C.tmp zbx124.tmp zbx1244.tmp
              zbx1251.tmp zbx1254.tmp zbx1263.tmp zbx127.tmp zbx1271.tmp
              zbx1276.tmp zbx128B.tmp zbx1293.tmp zbx1295.tmp zbx12A6.tmp
              zbx12B1.tmp zbx12BE.tmp zbx1304.tmp zbx131.tmp zbx131C.tmp
              zbx131D.tmp zbx131E.tmp zbx131F.tmp zbx1320.tmp zbx1321.tmp
              zbx1322.tmp zbx133A.tmp zbx1342.tmp zbx139A.tmp zbx13C5.tmp
              zbx1400.tmp zbx140A.tmp zbx1440.tmp zbx1441.tmp zbx1445.tmp
              zbx1461.tmp zbx147C.tmp zbx1481.tmp zbx149.tmp zbx14AA.tmp
              zbx14AE.tmp zbx14AF.tmp zbx14B0.tmp zbx14B1.tmp zbx14B2.tmp
              zbx14B3.tmp zbx14B4.tmp zbx14B5.tmp zbx14B6.tmp zbx14B7.tmp
              zbx14BA.tmp zbx14BB.tmp zbx14CE.tmp zbx14DC.tmp zbx14F.tmp
              zbx150F.tmp zbx153A.tmp zbx159C.tmp zbx15A0.tmp zbx15AB.tmp
              zbx15BB.tmp zbx15CB.tmp zbx15DE.tmp zbx15EF.tmp zbx167A.tmp
              zbx16D4.tmp zbx16E1.tmp zbx16E3.tmp zbx16F.tmp zbx170E.tmp
              zbx1727.tmp zbx1732.tmp zbx1741.tmp zbx1785.tmp zbx1795.tmp
              2623 File(s) 17Ъ497 bytes
              2 Dir(s) 17Ъ196Ъ273Ъ664 bytes free
              >type zbx10AF.tmp
              0.0061
              >type zbx109E.tmp
              1998146
              >type zbx127.tmp
              161
              >type zbx1020.tmp
              1
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                Upgrade your agent to 1.1.7.
                Alexei Vladishev
                New York | Tokyo | Riga
                My Twitter
                • den_crane
                  • Feb 2006
                  • 272
                  It support wildcards?
                  C:\blat>ZabbixW32.exe version
                  Zabbix Win32 Agent Version 1.1.7 Build of Mar 30 2007
                  C:\blat>ZabbixW32.exe --config C:\blat\zabbix_agentd.conf test oracle[version]
                  Using configuration file "C:\blat\zabbix_agentd.conf"
                  Configuration file OK
                  [18-Apr-2007 13:59:12] *************** Log file opened ****************
                  [18-Apr-2007 13:59:12] Collector thread initialized successfully
                  oracle[version] [ZBX_NOTSUPPORTED]
                  but
                  C:\blat>ZabbixW32.old.exe version
                  C:\blat>ZabbixW32.old.exe --config C:\blat\zabbix_agentd.conf test oracle[version]
                  Error in configuration file, line 28: unknown option "ListenIP"
                  [18-Apr-2007 14:00:17] *************** Log file opened ****************
                  [18-Apr-2007 14:00:17] Collector thread initialized successfully
                  [18-Apr-2007 14:00:17] Information: 1676 : Listen thread is Started.
                  [18-Apr-2007 14:00:17] Information: 1900 : Listen thread is Started.
                  [18-Apr-2007 14:00:17] Information: 1168 : Listen thread is Started.
                  [18-Apr-2007 14:00:17] Information: 2052 : Listen thread is Started.
                  [18-Apr-2007 14:00:17] Information: 2136 : Listen thread is Started.
                  [18-Apr-2007 14:00:17] Information: 1280 : Listen thread is Started.
                  [18-Apr-2007 14:00:17] Information: 704 : Listen thread is Started.
                  [18-Apr-2007 14:00:17] Information: 1728 : Listen thread is Started.
                  [18-Apr-2007 14:00:17] Information: 1308 : Listen thread is Started.
                  [18-Apr-2007 14:00:17] Information: 2160 : Listen thread is Started.
                  oracle[version] [Oracle Database 10g Enterprise Edition Release 10.2.0
                  .1.0 - Prod]
                  • den_crane
                    • Feb 2006
                    • 272
                    I could not unzip attachment:
                    unzip zabbixw32.zip
                    Archive: zabbixw32.zip
                    skipping: main.cpp unsupported compression method 98
                    skipping: config.cpp unsupported compression method 98
                    skipping: zabbixw32.h unsupported compression method 98
                    skipping: sysinfo.cpp unsupported compression method 98
                    skipping: execute.cpp unsupported compression method 98
                    skipping: ZabbixW32.exe unsupported compression method 98
                    skipping: active.cpp unsupported compression method 98
                    skipping: eventlog.cpp unsupported compression method 98
                    I'll try winrar, winzip, 7zip -- same problem.
                    I redownload attach by wget it's not help.
                    md5sum zabbixw32.zip
                    95d100442d1888ac5769f4d73d35b693 zabbixw32.zip
                    unzip -h
                    UnZip 5.52 of 28 February 2005, by Info-ZIP.
                    • den_crane
                      • Feb 2006
                      • 272
                      winzip 11, extract it.
                      wildcards work. fine. thanks.
                      • den_crane
                        • Feb 2006
                        • 272
                        hmm
                        Zabbix Win32 Agent Version 1.1.7.2 Build of Apr 11 2007
                        Directory of C:\WINNT\Temp
                        04/18/2007 02:53p <DIR> .
                        04/18/2007 02:53p <DIR> ..
                        04/18/2007 02:25p 9 zbx3444.tmp
                        04/18/2007 02:25p 9 zbx3445.tmp
                        04/18/2007 02:25p 9 zbx3446.tmp
                        04/18/2007 02:25p 3 zbx3447.tmp
                        04/18/2007 02:25p 3 zbx3448.tmp
                        04/18/2007 02:25p 3 zbx3449.tmp
                        04/18/2007 02:25p 7 zbx344A.tmp
                        04/18/2007 02:25p 11 zbx344B.tmp
                        04/18/2007 02:25p 8 zbx344C.tmp
                        04/18/2007 02:25p 7 zbx344D.tmp
                        04/18/2007 02:25p 7 zbx344E.tmp
                        04/18/2007 02:25p 4 zbx344F.tmp
                        04/18/2007 02:25p 8 zbx3450.tmp
                        04/18/2007 02:25p 5 zbx3451.tmp
                        04/18/2007 02:28p 3 zbx3453.tmp
                        04/18/2007 02:28p 7 zbx3454.tmp
                        04/18/2007 02:28p 3 zbx3455.tmp
                        04/18/2007 02:28p 8 zbx3456.tmp
                        04/18/2007 02:28p 9 zbx3457.tmp
                        04/18/2007 02:28p 7 zbx3458.tmp
                        04/18/2007 02:28p 9 zbx3459.tmp
                        04/18/2007 02:28p 11 zbx345C.tmp
                        04/18/2007 02:32p 8 zbx3461.tmp
                        04/18/2007 02:38p 3 zbx3465.tmp
                        04/18/2007 02:38p 7 zbx3466.tmp
                        04/18/2007 02:38p 3 zbx3467.tmp
                        04/18/2007 02:38p 8 zbx3468.tmp
                        04/18/2007 02:38p 9 zbx3469.tmp
                        04/18/2007 02:38p 7 zbx346A.tmp
                        04/18/2007 02:38p 9 zbx346B.tmp
                        04/18/2007 02:38p 8 zbx346C.tmp
                        • den_crane
                          • Feb 2006
                          • 272
                          in zabbix 117 execute.cpp
                          LONG H_Execute(char *cmd,char *arg,char **value)
                             // Create new process
                             if (!CreateProcess(NULL,ptr1,NULL,NULL,TRUE,0,NULL,NULL,&si,&pi))
                             else
                             // Remove temporary file
                             CloseHandle(hOutput);
                             DeleteFile(szTempFile);
                          in zabbix 1172 wildcards extension execute.cpp
                             else
                          • jlh
                            • Nov 2006
                            I think you are not right: the handle must be closed only if it was open. So correct code is this:
                            if (!CreateProcess(NULL,truecmd,NULL,NULL,TRUE,0,NULL ,NULL,&si,&pi)) {
                            WriteLog(MSG_CREATE_PROCESS_FAILED,EVENTLOG_ERROR_ TYPE,"se",truecmd,GetLastError());
                            ret = SYSINFO_RC_NOTSUPPORTED;
                            *value = strdup("1");
                            else {
                            // Wait for process termination and close all handles
                            if (bWait) {
                            LOG_DEBUG_INFO("s","Waiting");
                            WaitForSingleObject(pi.hProcess,INFINITE);
                            LOG_DEBUG_INFO("s","End of waiting");
                            CloseHandle(pi.hThread);
                            CloseHandle(pi.hProcess);
                            // Rewind temporary file for reading
                            SetFilePointer(hOutput,0,NULL,FILE_BEGIN);
                            *value=(char *)malloc(MAX_STRING_LEN); // Called and freed in function "ProcessCommand", pointer "strResult"
                            // Read process output
                            ReadFile(hOutput,*value,MAX_STRING_LEN-1,&dwBytes,NULL);
                            (*value)[dwBytes]=0;
                            ptr1=strchr(*value,'\r');
                            if (ptr1!=NULL) *ptr1=0;
                            ptr1=strchr(*value,'\n');
                            else
                            *value = strdup("0");
                            ret = SYSINFO_RC_SUCCESS;
                            if (bWait) {
                            return ret;
                            • den_crane
                              • Feb 2006
                              • 272
                              #15
                              I show differences between your code and zabbix code. I don't now how is right. I don't have vs to compile and check. But I steel have problem with thousands small files.
