$ /usr/bin/zabbix_sender -z 10.131.244.3 -p 8080 -s myhost -k mykey -o 1 -vv
zabbix_sender [18254]: DEBUG: Answer [{
"response":"success",
"info":"Processed 0 Failed 1 Total 1 Seconds spent 0.000477"}]
Info from server: "Processed 0 Failed 1 Total 1 Seconds spent 0.000477"
sent: 1; skipped: 0; total: 1
Zabbix Sender v1.8.3 (revision 13928) (16 August 2010)
Compilation time: Aug 27 2010 06:44:09
In zabbix_server.log
18397:20101015:174314.721 Process data failed: Connection from [10.131.244.2] rejected. Allowed server is [localhost]
Zabbix Server v1.8.3 (revision 13928) (16 August 2010)
Compilation time: Oct 4 2010 12:53:03
zabbix_server.conf trapper segment
ListenPort=8080 # Source IP address for outgoing connections #SourceIP= # Listen interface for trapper. Trapper will listen on all network interfaces # if this parameter is missing. #ListenIP=
ListenIP is unset so the trapper should reiceve zabbix_sender from everywhere...
