Please help! No data in frontend after update to 1.4
  • inko_nick
    • Mar 2007
    • 12
    After updating from 1.1.7 to 1.4 no data is shown in frontend, but it seems that zabbix collect the data. In Report>Status of Zabbix:
    Number of hosts (monitored/not monitored/templates/deleted) 162(153/1/8/0)
    Number of items (monitored/disabled/not supported)[trapper] 312(305/7/0)[6]
    Number of triggers (enabled/disabled)[true/unknown/false] 257(250/7)[4/1/245]
    Number of events 32836
    Alerts work just fine, but there is no data, no graph, no screen. Please help!
    Patch.mysql was applied.
    Thank's
  • inko_nick
    • Mar 2007
    • 12
    After changing the Admin value in user table all work fine.
    A little bug.
    • dfallin
      • May 2007
      i have a similar problem - appears (in the frontend) that all data is gone, but i can see it in the database. also, there is no 'Config' tab in the ui - what exactly did you do to make this work again? (i've logged in as 2 different admin users with same results)
      thanks!
      dwf
      • xobnis
        • Mar 2007
        • 14
        I had the exact same problem and when I logged in as admin there was no configuration tab. I editied the users table and changed my admin account's type to 2. After that everthing seemed to be fine.
        Hope this helps
        • jas
          • May 2007
          this should fix it:
          update users set type=3 where alias="Admin";
          • dfallin
            • May 2007
            thanks guys!! i found it shortly after posting (by perusing the php code! sure is nice to have the source!!) and you're right - the problem was that all my users became 'normal' or guest users. so i just set my admins (and a superadmin) types in the user table and violla!
            thanks for the quick response!! looking forward to playing with web monitoring and auto discovery!!
            dwf
            • xobnis
              • Mar 2007
              • 14
              There is one problem though with the way we are setting the users. By setting the "guest" user as an admin if you just want a simple monitor page the guest user as config rights. I created a "guest" group and then gave "read" access to all hosts/host-groups, then I added the guest user to the new guest group. Then set the guest acount back to a "zabbix user" and everthing works the way it use to. Sorry if this is a jumble of thoughts I was up pretty late tinkering with this and the coffee has not quite kicked in yet
              • xobnis
                • Mar 2007
                • 14
                Another note,
                I had to re-link all my hosts to their old templates. They were all working and had all the triggers but the link to the template was not there. Re-linking worked no problem.
