Cisco WLC Template
  • AQS
    • Dec 2021
    • 62
    Cisco WLC Template
    Tell me a working template for monitoring Cisco WLC, for version 5.4
    The main task of the trigger on the fall of the AP
  • lptarik
    • Oct 2021
    • 33
    Hello did you able to find it ?
    • AQS
      • Dec 2021
      • 62
      There is no finished one, but I assembled one from 3 and added info on the points:
      here is template 5.4
      Detects all APs, Shows information on points, including ping and number of clients,
      via wifi networks (number of clients at all points of the controller),
      and by clients (not completed / disabled, meaningless with 5k clients)
      • AQS
        AQS commented
        Ryner.Chen
        You can find the oid that suits you with the command:
        snmpwalk -c {community) -v 2c {X.X.X.X ip WLC} {OID-wifi-ap} | grep {SSIDNAME}
      • Chose
        Chose commented
        Works with 8.5.182.0. This is the one and unique template you need!
      • shahob
        shahob commented
        Good day!
        Please tell me if you have a ready-made XML file for export to Zabbix 4.2.5. © 2001–2019, Zabbix SIA
        I have version cisco wlc 2500
    • tinzoo
      • Jun 2022
      Hi everybody, need to some insight about this template, im running it on zabbix 6, but no one data what you tell show
      • petermilburn
        • Jul 2022
        Does anyone know how to calculate the total number of users. I did have it running by adding each AP last(/192.168.45.15/bsnApIfNoOfUsers1[Hartzer-ConferenceRoom])+
        last(/192.168.45.15/bsnApIfNoOfUsers1[APE44E.2DB5.55A4]) in the formulate for a calculated item. I went to re-create it and now it is not working. Getting a can't evaluate expression error
        • mooping
          • Oct 2022
          Works with version 5.4, thanks!!!
          • AQS
            • Dec 2021
            • 62
            discovery[{#SNMPVALUE},1.3.6.1.4.1.14179.2.1.1.1.2]
            Detects all wifi networks
            1.3.6.1.4.1.14179.2.1.1.1.38.{#SNMPINDEX}
            Number of users on the network
            So it's easier to summarize
            • AQS
              • Dec 2021
              • 62
              Here is a new version, requires zabbix 6.2(!!!), now wifi APs are created as separate devices, with interface and data from WLC, AP direct ping, and AP-WLC ping (it is assumed that all APs have a preferred controller, in cases if there is more than one WLC)
              Warning! Some of the titles and descriptions are in Russian, translate.google.com will help.​
              • AQS
                • Dec 2021
                • 62
                More, on what swears? Which error messages on which items (Settings - Hosts - WLC Host - Items)
                • maupet
                  • Jun 2022
                  Hi Everybody!
                  I tried to use new WLC template but didn't work for me.
                  Almost every ITEM is red, attachment picture
                  WLC 5520 Software version: 8.10.171.0
                  AP Boot Version:​ snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.1.1.9.{$SNMPINDEX}".
                  AP ICMP: ping​ fping failed: {$SNMPIPAD}: Name or service not known
                  AP If No Of Users 2.4 GHz: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.2.1.15.{$SNMPINDEX}.0".
                  AP If No Of Users 5 GHz: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.2.1.15.{$SNMPINDEX}.1".
                  AP If Phy Channel Number 2.4 GHz: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.2.1.4.{$SNMPINDEX}.0".
                  AP If Phy Channel Number 5 GHz: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.2.1.4.{$SNMPINDEX}.1".
                  AP Ip Address: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.1.1.19.{$SNMPINDEX}".
                  AP MAC Address Ethernet: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.1.1.33.{$SNMPINDEX}".
                  AP MAC Address WiFi: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.1.1.1.{$SNMPINDEX}"
                  AP Model: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.1.1.16.{$SNMPINDEX}".
                  AP Serial Number: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.1.1.17.{$SNMPINDEX}"
                  AP Software Version: snmp_parse_oid(): cannot parse OID "1.3.6.1.4.1.14179.2.2.1.1.8.{$SNMPINDEX}​Click image for larger version
                  • AQS
                    • Dec 2021
                    • 62
                    As far as I can see, you have not set the macro {SNMPINDEX}
                    Have you attached the WLC_62_AP template?
                    Not this way.
                    You must attach the WLC_62 template. It will create hosts on its own with the WLC_62_AP template.​
                    • petermilburn
                      petermilburn commented
                      New to this side of things. What would you put in the macro SNMPINDEX
                  • ciberfred
                    • Nov 2022
                    should be put un git to allow more users to use it. works like a charm on 6.2
                    • FORCEKPI
                      • May 2023
                      Who can share the finished template? 6.2 doesn't help
                      • Ryner.Chen
                        • Jun 2023
ID:	465334​thanks a lot ,but it cant get the information for numbers of user of SSID and cpu.mem,HA, ap.joinStatus on Cisco WLC C9800.how do add these item in template ?
                        • marco_a
                          • Mar 2023
                          #15
                          Hi, I just started using zabbix.
                          One question...to configure AP discovery, I enabled 'WLC Client Data' and 'WLC Interface data' (template_Cisco_WiFi_WLC_62).
                          What should I do to create a host for each AP? How do I use the second template_Cisco_WiFi_WLC_62_AP? Thank you​
