Preprocessing step change of order
  • BigSmooth
    • Jun 2023
    • 46
    I am running Zabbix 6.4.7.
    I am playing with Apache Solr by HTTP template. In the template, item Solr: JVM memory heap usage (key: solr.jvm.memory.heap.usage), there are two preprocessing steps:
    1. JSONPath
    2. Custom multiplier
    This is the order visible in template item.
    When I go in host, item and then preprocessing steps, steps are inverted. This causes a failure:
    Failed: cannot apply multiplier "100" to value of type "string": cannot convert value to numeric type
    Did anyone saw that before?
    Olivier
    • 5002
    Are you sure they are inverted? Maybe your jsonpath returns a string and then second step fails? For example its not just a number, but number in ""-s or in []-s ?
    You should be able to test this item by directly retrieving value from host and you should see all preprocessing steps and their results...
    • BigSmooth
      • Jun 2023
      • 46
      Apparently, it is my additional template layer (which includes several templates) which causes this. Workaround is simple: Do not include template. Neverthelss, it can still be considered a bug. What do you think ?
      On Apache SOLR template:
Name:	Apache SOLR Template.png
      On my template which include Apache Solr template:
Name:	My Alfresco template.png
      On host:
        • 5002
        If you can replicate it easily, you can write a bug report here https://support.zabbix.com/projects/ZBX/issues
        • arusso
          • Jun 2022
          BigSmooth did you ever figure this out / submit an issue? I'm seeing this issue myself on 6.4.6.
          • arusso
            • Jun 2022
            I managed to work around it by deleting the last step of the preprocess (discard w/heartbeat), save, then re-add it. Once discovery ran again it sorted itself out.
            • duchenpaul
              • Apr 2024
              I can confirm this issue, it happens to me as well:
              I am using https://github.com/zabbix/zabbix/tre.../db/postgresql, getting errors one of items, and it turns out to be the preprocessing step in revert order.
              I tried to recreate the host using template for multiple times, no luck.
