Interface up/down flapping trigger
  • Mechanix
    • Jan 2017
    • 92
    I have this trigger in place to notify me if a interface goes from status up to down.
    {Template Datacenter:ifOperStatus[{#SNMPVALUE}].avg(5m)}<2 and {Template Datecenter:ifOperStatus[{#SNMPVALUE}].last()}=2 and {Template Datacenter:ifAlias[{#SNMPVALUE}].str(this_does_not_exist)}=0
    This works well. However we got a couple of interfaces (mainly VPN Tunnel endpoints) which goes fro a couple of seconds down during the night.
    How can fire up the trigger only if the interface has been down for lets say =3 minutes?
    Any hint is much appreciated.
    Cheers
  • Mechanix
    • Jan 2017
    • 92
    Sorry to push this: any thoughts? Thank you
    • Semiadmin
      • Oct 2014
      • 1626
      {Template Datacenter:ifOperStatus[{#SNMPVALUE}].count(3m,2,eq)}=3 and {Template Datacenter:ifOperStatus[{#SNMPVALUE}].count(3m,2,eq,3m)}<>3
      P.S. If update interval = 60 s, of course.
      • Mechanix
        • Jan 2017
        • 92
        Thank you for your reply. I will test the trigger.
        Can you explain what this line does:
        count(3m,2,eq)
        specially the 2
        • Mechanix
          • Jan 2017
          • 92
          Sorry to say but this trigger is generating a lot of alarms on interfaces that are already down
          • Semiadmin
            • Oct 2014
            • 1626
            Are you sure you use whole trigger expression? The seconfd part {Template Datacenter:ifOperStatus[{#SNMPVALUE}].count(3m,2,eq,3m)}<>3 must prevent alert then interface is down over 3 min. And in your case may be add the third part "and {Template Datacenter:ifAlias[{#SNMPVALUE}].str(this_does_not_exist)}=0".
            • Mechanix
              • Jan 2017
              • 92
              Yes, the trigger looks like this:
              {Template Datacenter:ifOperStatus[{#SNMPVALUE}].count(3m,2,eq)}=3 and {Template Datacenter:ifOperStatus[{#SNMPVALUE}].count(3m,2,eq,3m)}<>3 and {Template Datacenter:ifAlias[{#SNMPVALUE}].str(this_does_not_exist)}=0
              • Semiadmin
                • Oct 2014
                • 1626
                It's a strange thing. I just tested this trigger,of cource without the third part, it fired after 3th min. of a problem and cleared after 6th.
                • Mechanix
                  • Jan 2017
                  • 92
                  Hmm...your trigger doesnt check if the port was last down or not:
                  {Template Datacenter:ifOperStatus[{#SNMPVALUE}].last(0)}=2
                  And I do not understand this line. .count(3m,2,eq)}=3
                  why ...=3 because the values should be 1(up) 2(down)
                  Thx
                  • Semiadmin
                    • Oct 2014
                    • 1626
                    The 1st part of the trigger counts how many times ( =3) ifOperStatus was in state 2(down) (2 eq) during 3m.
                    The 2nd part counts the same with timeshift 3 min. "<>3" means ifOperStatus wasn't down during 3m 3m ago.
                    • Mechanix
                      • Jan 2017
                      • 92
                      well, thats the problem: the trigger should fire only when the interface was UP (<2) before
                      To be more specific: fire trigger only when the interface went from UP to DOWN and stays in DOWN state for at least 3 minutes.
                      • Semiadmin
                        • Oct 2014
                        • 1626
                        ({Template Datacenter:ifOperStatus[{#SNMPVALUE}].last(#4)}=1 and {Template Datacenter:ifOperStatus[{#SNMPVALUE}].min(#3)}=2 and {TRIGGER.VALUE}=0) or ({Template Datacenter:ifOperStatus[{#SNMPVALUE}].min(#3)}=2 and {TRIGGER.VALUE}=1)
                        where item update interval is equal 1 min.
                        • Mechanix
                          • Jan 2017
                          • 92
                          Thank you very much, this seems to work
                          • moshe
                            • Jan 2019
                            • 37
                            Trying to create toggling/flapping trigger on ifOperStatus.
                            The condition for the increase an alarm is 5 times (up and down status) in last 1 Hour.
                            I would be very happy to help.
                            • soufyanelaksibi
                              • Apr 2021
                              hello everyone
                              I'm trying to monitor a huawei firewall using SNMP, when the port that connect this firewall to zabbix server is unplugged i get this message ^Unavailable by ICMP ping^ ,need to get an alert of the status of the port (up or down ) with its number .
                              Thanks in advance
