sudo and tty requirement
  • scldad
    • Mar 2013
    • 18
    If, from the Maps page, I select Detect Operating System, I get:
    sudo:sorry, you must have a tty to run sudo.
    I understand the message but do not know how to work around it from within Zabbix.
    Cheers,
    Stephen
  • ZehEmEe
    • Feb 2013
    • 17
    place
    "Defaults:username !requiretty"
    in zabbix sudoers file. This should solve your problem.
    I know the problem from centos/redhat systems.
    • scldad
      • Mar 2013
      • 18
      Did that but now I get:
      sudo: no tty present and no askpass program specified
      • ZehEmEe
        • Feb 2013
        • 17
        sudoers file
        Ca you please post your sudoers file. Please mark the problem command.
        Cheers
        • scldad
          • Mar 2013
          • 18
          Here is the sudoers file.
          Only the one line you suggested has been changed from the default.
          The sudo log file has:
          Mar 4 09:50:38 : zabbix : HOST=server : sorry, you must have a tty to run sudo
          ; TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/nmap -O 127.0.0.1
          Mar 6 10:00:58 : root : HOST=server : TTY=pts/4 ; PWD=/root ; USER=root ;
          COMMAND=sudoedit /etc/sudoers
          Mar 6 10:02:51 : root : HOST=server : TTY=pts/4 ; PWD=/root ; USER=root ;
          Mar 6 10:04:11 : root : HOST=server : TTY=pts/4 ; PWD=/root ; USER=root ;
          Mar 6 10:05:28 : zabbix : HOST=server : no tty present and no askpass program
          specified ; TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/nmap -O 127.0.0.1
          Mar 6 10:10:08 : zabbix : HOST=server : no tty present and no askpass program
          • scldad
            • Mar 2013
            • 18
            The previous attach seems to have not worked.
            Trying again with the file rename4d to sudoers.txt.
            Stephen
            • ZehEmEe
              • Feb 2013
              • 17
              thanks for sudoers file. But i can't find any entry for user "zabbix" in it.
              Maybe you have to define the needed command.
              This is the only content which sudo uses effectively.
              Defaults    requiretty
              Defaults:zabbix    !requiretty
              Defaults    env_reset
              Defaults    env_keep =  "COLORS DISPLAY HOSTNAME HISTSIZE INPUTRC KDEDIR LS_COLORS"
              Defaults    env_keep += "MAIL PS1 PS2 QTDIR USERNAME LANG LC_ADDRESS LC_CTYPE"
              Defaults    env_keep += "LC_COLLATE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGES"
              Defaults    env_keep += "LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE"
              Defaults    env_keep += "LC_TIME LC_ALL LANGUAGE LINGUAS _XKB_CHARSET XAUTHORITY"
              Defaults    secure_path = /sbin:/bin:/usr/sbin:/usr/bin
              root	ALL=(ALL) 	ALL
              %wheel	ALL=(ALL)	ALL
              You have to define some Commands for user "zabbix" or may be user "zabbix" is member of group "wheel".
              I suggest you remove the comment of this line:
              #includedir /etc/sudoers.d
              and then you can collect all sudo commands for zabbix a single files there.
              • scldad
                • Mar 2013
                • 18
                I have no idea which commands user/server zabbix might try so I added an ALL entry but it made no difference.
                I still get sudo: no tty present and no askpass program specified.
                My understanding is that, given that there is no tty, sudo needs a helper (askpass) in order to get the password but there isn't one.
                I don't want to go digging into the Zabbix source to change this. There must be a better way.
                Cheers,
                Stephen
                • scldad
                  • Mar 2013
                  • 18
                  Solved
                  The solution to this issue is in the 1.8 documentation in the Tutorials section.
                  (Google found it for me.)
                  Cheers,
                  Stephen
                  • alledm
                    • May 2012
                    • 84
                    Hi, just to point out that comment character is required for sudo to work
                    ## Read drop-in files from /etc/sudoers.d (the # here does not mean a comment)
                    I personally use a zabbix_sudo file that I drop in the above directory.
                    The content is
                    Cmnd_Alias ZABBIX_CMD = /sbin/fuser, /usr/sbin/lsof, /usr/sbin/dmidecode, /sbin/mii-tool, /sbin/ethtool, /usr/bin/ipmitool, /usr/sbin/iptstate, /usr/bin/ocaudit
                    zabbix   ALL = (other_user)  NOPASSWD: ALL
                    zabbix   ALL = (root)        NOPASSWD: ZABBIX_CMD
                    • hpeti2
                      • Jul 2015
                      • 29
                      Hi all!
                      I followed the above instructions and get a very annoying fault.
                      I made a test setup:
                      /home/ubuntu/roottest file with 0400 permissions. This file contains only "root_test_text"
                      /etc/sudoers.d/zabbix contains:
                      Cmnd_Alias ZABBIX_CMD = /bin/more
                      /etc/zabbix/zabbix_agent.conf:
                      AllowRoot=0
                      UserParameter=roottest, sudo more /home/ubuntu/roottest
                      I thought the response for "zabbix_get -s xxx.xxx.xxx.xxx -k roottest" command on zabbix server will be root_test_text but i got:
                      root_test_text
                      Any idea?
                      • Atsushi
                        • Aug 2013
                        • 2028
                        Please try to use the "cat" command instead of "more" command at UserParameter.
                        • hpeti2
                          • Jul 2015
                          • 29
                          It works. Thanks.
                          • GLutz
                            • Apr 2016
                            Cheers,
                            Stephen
                            Hi, I had the same problem, and I did this:
                            place
                            Then I got the same as this:
                            Then I found this tutorial:
                            Which is basicaly install nmap and run this command:
                            echo "zabbix ALL=(ALL:ALL) NOPASSWD:/usr/bin/nmap" >> /etc/sudoers
                            Restarted the service and It worked.
