Announcement
No announcement yet.
reset statistic
  • Filter
    reset statistic
    Can i set a new start date for the statistics calculation ?
    (I want to skip the "unknown" period).
    I'm not sure what you mean. You may delete everything from tables alerts, alarms, history, history_str, service_alarms and trends to get rid of collected information. This will not affect configuration of ZABBIX.
    The following steps have to be performed:
    1. Stop ZABBIX
    2. Delete everything from mentioned tables (use MySQL truncate table <table> statement to do it fast)
    3. Start ZABBIX
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
      Not fast
      Note that under InnoDB, a truncate table is implemented the same as a delete, so it is *not* fast, and cancelling it halfway through causes it to roll back, also not fast.
