Zabbix version 6 LTS after upgrade some variables are not replaced
  • BalaC
    • Sep 2021
    • 22
    After upgrade to Zabbix 6 LTS, It seems that some variables are not filled anymore since the update.
    and e.g. here for CPU load and network traffic screen - "$2" should actually be the CPU ID/number and "$1" should actually be the interface name.
    If we import the new template for OS then will loose old data. Anyone faced similar issue?
  • LenR
    • Sep 2009
    • 1011
    The $1, $2 macros were deprecated, it was announced (I think) in the 4.x to 5.0 conversion but not enforced until 6.0. I think this is an old template shipped by Zabbix, you'll either need to update these items or replace the template with the newer one. I have a python API script that will find them all I can share if you want it.
    If you fix the item names in the current templates, you won't lose the old data. The edit is trivial, the value referred to is the positional key value. In LLD items, it may be a macro, just copy what is there replacing the $1 in the name.
    I put the script on github https://github.com/rugenl/zabbix-api...macro_items.py
    • tim.mooney
      tim.mooney commented
      Thanks for sharing your script!
  • BalaC
    • Sep 2021
    • 22
    Thanks a lot for the reply and the script. I will check it further.
    • BalaC
      • Sep 2021
      • 22
      Hi, By using the script we can see 860 items to fix manually. Do you have a clue about what should replace the $*. We got the entire list from the script you given but what exactly we need to replace please.​
      Thanks.
        • 4996
        Probably appropriate LLD macro from discovery.
