Custom on failure → Set value: 0 not working (wrong value type error)
  • GChmurka
    • Jun 2024
    • 21
    I have a simple item with type Numeric (unsigned) and the following key:
    vfs.file.contents[/sys/block/md0/md/sync_speed]
    The content of this file can be either a number or "none".
    Despite setting preprocessing:
Name:	Zrzut ekranu z 2025-02-04 22-01-50.png
    I still get the error:
    Value of type "string" is not suitable for value type "Numeric (unsigned)". Value "none"
    ​Is this the expected behavior in Zabbix?
    I'm using version 7.0.8.
    • 4913
    You are trying to save string value to numeric field... you are getting "none". It is not a error.
    "Check for not supported value" would work, for example, if that file is not found any more.
    Use "Replace" preprocessing to replace "none" with 0 and you should be fine. If there is a number, it will be passed on as "none" is not found, nothing is replaced.
    • GChmurka
      • Jun 2024
      • 21
      Alright, I’ve learned that a 'not supported value' is a value that, for example, does not have a key in userprefs.
      I found that the best way to ensure a value is always a number or gets discarded in Zabbix preprocessing is to use:
      1. Multiply by 1 – this forces the value to be numeric (if it's not, it will cause an error).
      2. Custom on fail → Discard value – if the operation fails (e.g., the value is text), Zabbix will discard it.
