CPU Usage Of A Process
  • gpmidi
    • Aug 2009
    • 62
    Is there any way to monitor the CPU usage of a process with a given name? Either in % or seconds? I'm just wondering if I missed something in the docs or a way to do it other than a script.
  • tchjts1
    • May 2008
    • 1605
    Pretty easy to do on Windows using PerfMon counters and UserParameters.
    What platform are you talking about?
    • gpmidi
      • Aug 2009
      • 62
      Linux
      Linux, mostly RHEL 5
      -Paul
      • thiagomz
        • Jan 2010
        • 74
        In nmon (IBM/Linux) you have this information. It will be welcome in zabbix.
        • gpmidi
          • Aug 2009
          • 62
          Yes but how do you get the info into Zabbix? I can script it to pull the CPU time out of /proc/<pid> pretty easy. But I was hoping there was a more efficient way that I had missed.
          -Paul
          • MrKen
            • Oct 2008
            • 652
            Actually, I was asked to do the same thing just yesterday, and came across an ancient post from 2005.
            UserParameter=httpd[cpu],ps auxw|grep httpd|grep -v grep| awk '{s+=$3} END {print s}'
            Seems to work ok. Gives the same values that you will see in 'top'.
            MrKen
            • MrKen
              • Oct 2008
              • 652
              Addendum:
              You may see values like 'httpd - 240%', and of course that cannot be correct. To correct this you need to divide by the number of cpu's. For example if the server has 4 cpu's, you will end up with a value of 60%, which is most probably closer to the real value.
              This can be done in the item configuration, Use Multiplier. For 4 cpu's you multiply by 0.25
              MrKen
              • gpmidi
                • Aug 2009
                • 62
                Altiris
                Products such as Altiris have the option of monitoring all processes. Not just pre-selected ones. It's this type of feature that I'd like to see in Zabbix.
                -Paul
                • zabbix_zen
                  • Jul 2009
                  • 426
                  If you have a constructive remark why not filling it into the Request Tracker?
