Hi Alle,
ich kriege den Agenten unter Debian 10 nicht zum senden oder der Server verhindert das Empfangen.
Wo ist da der Fehler ?
Besten Dank!
zabbix_agentd.conf
URL=https://www.directupload.net]
[/URL]
Besten Dank!
● zabbix-agent.service - Zabbix Agent Loaded: loaded (/lib/systemd/system/zabbix-agent.service; disabled; vendor preset: enabled) Active: active (running) since Wed 2021-01-13 16:23:28 CET; 28min ago Process: 24796 ExecStart=/usr/sbin/zabbix_agentd -c $CONFFILE (code=exited, status=0/SUCCESS) Main PID: 24804 (zabbix_agentd) Tasks: 6 (limit: 4915) Memory: 10.7M CGroup: /system.slice/zabbix-agent.service ├─24804 /usr/sbin/zabbix_agentd -c /etc/zabbix/zabbix_agentd.conf ├─24805 /usr/sbin/zabbix_agentd: collector [idle 1 sec] ├─24806 /usr/sbin/zabbix_agentd: listener #1 [waiting for connection] ├─24807 /usr/sbin/zabbix_agentd: listener #2 [waiting for connection] ├─24808 /usr/sbin/zabbix_agentd: listener #3 [waiting for connection] └─24809 /usr/sbin/zabbix_agentd: active checks #1 [idle 1 sec] Jan 13 16:23:28 pve systemd[1]: Starting Zabbix Agent... Jan 13 16:23:28 pve systemd[1]: Started Zabbix Agent.
Server=135.xxx.xxx.xxx ListenPort=10050 Hostname=Proxmox73 ServerActive=135.xxx.xxx.xxx
[URL=https://www.directupload.net]
[/URL]
