Hallo Zusammen,
seit paar Tagen läuft unser Zabbix Server nicht mehr.
Als Fehler wird mir angezeigt
zabbix_server.log
zabbix_agentd.log
Danke schon mal
| Get value from agent failed: TCP successful, cannot establish TLS to [[127.0.0.1]:10050]: SSL_connect() I/O error: [0] Success |
58995:20210924:111903.161 === Backtrace: === 58995:20210924:111903.163 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3f) [0x563d2f93552d] 58995:20210924:111903.163 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_realloc+0x160) [0x563d2f93032c] 58995:20210924:111903.163 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x199648) [0x563d2f8bb648] 58995:20210924:111903.163 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_reserve+0xc1) [0x563d2f93b2e4] 58995:20210924:111903.163 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert_ext+0xec) [0x563d2f93b559] 58995:20210924:111903.163 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert+0x2d) [0x563d2f93b46b] 58995:20210924:111903.163 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCfind_id+0x86) [0x563d2f8bbe2b] 58995:20210924:111903.163 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1a5b64) [0x563d2f8c7b64] 58995:20210924:111903.163 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x1185) [0x563d2f8ca33e] 58995:20210924:111903.163 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x122) [0x563d2f788708] 58995:20210924:111903.163 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x563d2f94547e] 58995:20210924:111903.163 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xb39) [0x563d2f776d3d] 58995:20210924:111903.163 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x2ff) [0x563d2f935157] 58995:20210924:111903.163 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x2f6) [0x563d2f776130] 58995:20210924:111903.163 1: /lib64/libc.so.6(__libc_start_main+0xf3) [0x7f7f0bc34493] 58995:20210924:111903.163 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x563d2f77502e] 58994:20210924:111903.167 One child process died (PID:58995,exitcode/signal:1). Exiting ... 58994:20210924:111903.169 syncing trend data... 58994:20210924:111903.169 syncing trend data done 58994:20210924:111903.169 Zabbix Server stopped. Zabbix 5.4.4 (revision 1765c4f1bc). 59001:20210924:111913.397 Starting Zabbix Server. Zabbix 5.4.4 (revision 1765c4f1bc). 59001:20210924:111913.397 ****** Enabled features ****** 59001:20210924:111913.397 SNMP monitoring: YES 59001:20210924:111913.397 IPMI monitoring: YES 59001:20210924:111913.397 Web monitoring: YES 59001:20210924:111913.397 VMware monitoring: YES 59001:20210924:111913.397 SMTP authentication: YES 59001:20210924:111913.397 ODBC: YES 59001:20210924:111913.397 SSH support: YES 59001:20210924:111913.397 IPv6 support: YES 59001:20210924:111913.397 TLS support: YES 59001:20210924:111913.397 ****************************** 59001:20210924:111913.397 using configuration file: /etc/zabbix/zabbix_server.conf 59001:20210924:111913.408 current database version (mandatory/optional): 05040000/05040000 59001:20210924:111913.408 required mandatory version: 05040000 59001:20210924:111913.435 server #0 started [main process] 59002:20210924:111913.436 server #1 started [configuration syncer #1] 59002:20210924:111914.158 __mem_malloc: skipped 7 asked 48088 skip_min 336 skip_max 19464 59002:20210924:111914.158 [file:dbconfig.c,line:102] __zbx_mem_realloc(): out of memory (requested 48088 bytes) 59002:20210924:111914.158 [file:dbconfig.c,line:102] __zbx_mem_realloc(): please increase CacheSize configuration parameter 59002:20210924:111914.158 === memory statistics for configuration cache === 59002:20210924:111914.158 free chunks of size 24 bytes: 24 59002:20210924:111914.158 free chunks of size >= 256 bytes: 7 59002:20210924:111914.158 min chunk size: 24 bytes 59002:20210924:111914.158 max chunk size: 19464 bytes 59002:20210924:111914.158 memory of total size 7326312 bytes fragmented into 66371 chunks 59002:20210924:111914.158 of those, 41488 bytes are in 31 free chunks 59002:20210924:111914.158 of those, 7284824 bytes are in 66340 used chunks 59002:20210924:111914.158 of those, 1061920 bytes are used by allocation overhead 59002:20210924:111914.158 ================================ 59002:20210924:111914.158 === Backtrace: === 59002:20210924:111914.160 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3f) [0x5587abe2252d] 59002:20210924:111914.160 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_realloc+0x160) [0x5587abe1d32c] 59002:20210924:111914.160 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x199648) [0x5587abda8648] 59002:20210924:111914.160 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_reserve+0xc1) [0x5587abe282e4] 59002:20210924:111914.160 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert_ext+0xec) [0x5587abe28559] 59002:20210924:111914.160 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert+0x2d) [0x5587abe2846b] 59002:20210924:111914.160 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCfind_id+0x86) [0x5587abda8e2b] 59002:20210924:111914.160 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1a5b64) [0x5587abdb4b64] 59002:20210924:111914.160 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x1185) [0x5587abdb733e] 59002:20210924:111914.160 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x122) [0x5587abc75708] 59002:20210924:111914.160 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x5587abe3247e] 59002:20210924:111914.160 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xb39) [0x5587abc63d3d] 59002:20210924:111914.160 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x2ff) [0x5587abe22157] 59002:20210924:111914.160 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x2f6) [0x5587abc63130] 59002:20210924:111914.160 1: /lib64/libc.so.6(__libc_start_main+0xf3) [0x7fbc98cef493] 59002:20210924:111914.160 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x5587abc6202e] 59001:20210924:111914.164 One child process died (PID:59002,exitcode/signal:1). Exiting ... 59001:20210924:111914.166 syncing trend data... 59001:20210924:111914.167 syncing trend data done 59001:20210924:111914.167 Zabbix Server stopped. Zabbix 5.4.4 (revision 1765c4f1bc). 59008:20210924:111924.398 Starting Zabbix Server. Zabbix 5.4.4 (revision 1765c4f1bc). 59008:20210924:111924.398 ****** Enabled features ****** 59008:20210924:111924.398 SNMP monitoring: YES 59008:20210924:111924.398 IPMI monitoring: YES 59008:20210924:111924.398 Web monitoring: YES 59008:20210924:111924.398 VMware monitoring: YES 59008:20210924:111924.398 SMTP authentication: YES 59008:20210924:111924.398 ODBC: YES 59008:20210924:111924.398 SSH support: YES 59008:20210924:111924.399 IPv6 support: YES 59008:20210924:111924.399 TLS support: YES 59008:20210924:111924.399 ****************************** 59008:20210924:111924.399 using configuration file: /etc/zabbix/zabbix_server.conf 59008:20210924:111924.409 current database version (mandatory/optional): 05040000/05040000 59008:20210924:111924.409 required mandatory version: 05040000 59008:20210924:111924.436 server #0 started [main process] 59009:20210924:111924.437 server #1 started [configuration syncer #1] 59009:20210924:111925.160 __mem_malloc: skipped 7 asked 48088 skip_min 336 skip_max 19464 59009:20210924:111925.160 [file:dbconfig.c,line:102] __zbx_mem_realloc(): out of memory (requested 48088 bytes) 59009:20210924:111925.160 [file:dbconfig.c,line:102] __zbx_mem_realloc(): please increase CacheSize configuration parameter 59009:20210924:111925.160 === memory statistics for configuration cache === 59009:20210924:111925.160 free chunks of size 24 bytes: 24 59009:20210924:111925.160 free chunks of size >= 256 bytes: 7 59009:20210924:111925.160 min chunk size: 24 bytes 59009:20210924:111925.160 max chunk size: 19464 bytes 59009:20210924:111925.160 memory of total size 7326312 bytes fragmented into 66371 chunks 59009:20210924:111925.160 of those, 41488 bytes are in 31 free chunks 59009:20210924:111925.160 of those, 7284824 bytes are in 66340 used chunks 59009:20210924:111925.160 of those, 1061920 bytes are used by allocation overhead 59009:20210924:111925.160 ================================ 59009:20210924:111925.160 === Backtrace: === 59009:20210924:111925.162 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3f) [0x565192b5052d] 59009:20210924:111925.162 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_realloc+0x160) [0x565192b4b32c] 59009:20210924:111925.162 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x199648) [0x565192ad6648] 59009:20210924:111925.162 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_reserve+0xc1) [0x565192b562e4] 59009:20210924:111925.162 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert_ext+0xec) [0x565192b56559] 59009:20210924:111925.162 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert+0x2d) [0x565192b5646b] 59009:20210924:111925.162 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCfind_id+0x86) [0x565192ad6e2b] 59009:20210924:111925.162 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1a5b64) [0x565192ae2b64] 59009:20210924:111925.162 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x1185) [0x565192ae533e] 59009:20210924:111925.162 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x122) [0x5651929a3708] 59009:20210924:111925.162 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x565192b6047e] 59009:20210924:111925.162 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xb39) [0x565192991d3d] 59009:20210924:111925.162 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x2ff) [0x565192b50157] 59009:20210924:111925.162 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x2f6) [0x565192991130] 59009:20210924:111925.162 1: /lib64/libc.so.6(__libc_start_main+0xf3) [0x7f61c9d37493] 59009:20210924:111925.162 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x56519299002e] 59008:20210924:111925.166 One child process died (PID:59009,exitcode/signal:1). Exiting ... 59008:20210924:111925.168 syncing trend data... 59008:20210924:111925.168 syncing trend data done 59008:20210924:111925.169 Zabbix Server stopped. Zabbix 5.4.4 (revision 1765c4f1bc). 59033:20210924:111935.397 Starting Zabbix Server. Zabbix 5.4.4 (revision 1765c4f1bc). 59033:20210924:111935.397 ****** Enabled features ****** 59033:20210924:111935.397 SNMP monitoring: YES 59033:20210924:111935.397 IPMI monitoring: YES 59033:20210924:111935.397 Web monitoring: YES 59033:20210924:111935.397 VMware monitoring: YES 59033:20210924:111935.397 SMTP authentication: YES 59033:20210924:111935.398 ODBC: YES 59033:20210924:111935.398 SSH support: YES 59033:20210924:111935.398 IPv6 support: YES 59033:20210924:111935.398 TLS support: YES 59033:20210924:111935.398 ****************************** 59033:20210924:111935.398 using configuration file: /etc/zabbix/zabbix_server.conf 59033:20210924:111935.408 current database version (mandatory/optional): 05040000/05040000 59033:20210924:111935.408 required mandatory version: 05040000 59033:20210924:111935.433 server #0 started [main process] 59034:20210924:111935.435 server #1 started [configuration syncer #1] 59034:20210924:111936.178 __mem_malloc: skipped 7 asked 48088 skip_min 336 skip_max 19464 59034:20210924:111936.178 [file:dbconfig.c,line:102] __zbx_mem_realloc(): out of memory (requested 48088 bytes) 59034:20210924:111936.178 [file:dbconfig.c,line:102] __zbx_mem_realloc(): please increase CacheSize configuration parameter 59034:20210924:111936.178 === memory statistics for configuration cache === 59034:20210924:111936.178 free chunks of size 24 bytes: 24 59034:20210924:111936.178 free chunks of size >= 256 bytes: 7 59034:20210924:111936.178 min chunk size: 24 bytes 59034:20210924:111936.178 max chunk size: 19464 bytes 59034:20210924:111936.178 memory of total size 7326312 bytes fragmented into 66371 chunks 59034:20210924:111936.178 of those, 41488 bytes are in 31 free chunks 59034:20210924:111936.178 of those, 7284824 bytes are in 66340 used chunks 59034:20210924:111936.178 of those, 1061920 bytes are used by allocation overhead 59034:20210924:111936.178 ================================ 59034:20210924:111936.178 === Backtrace: === 59034:20210924:111936.180 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3f) [0x55915be3952d] 59034:20210924:111936.180 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_realloc+0x160) [0x55915be3432c] 59034:20210924:111936.180 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x199648) [0x55915bdbf648] 59034:20210924:111936.180 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_reserve+0xc1) [0x55915be3f2e4] 59034:20210924:111936.180 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert_ext+0xec) [0x55915be3f559] 59034:20210924:111936.180 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert+0x2d) [0x55915be3f46b] 59034:20210924:111936.180 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCfind_id+0x86) [0x55915bdbfe2b] 59034:20210924:111936.180 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1a5b64) [0x55915bdcbb64] 59034:20210924:111936.180 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x1185) [0x55915bdce33e] 59034:20210924:111936.180 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x122) [0x55915bc8c708] 59034:20210924:111936.180 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x55915be4947e] 59034:20210924:111936.180 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xb39) [0x55915bc7ad3d] 59034:20210924:111936.180 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x2ff) [0x55915be39157] 59034:20210924:111936.180 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x2f6) [0x55915bc7a130] 59034:20210924:111936.180 1: /lib64/libc.so.6(__libc_start_main+0xf3) [0x7fce62c12493] 59034:20210924:111936.180 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x55915bc7902e] 59033:20210924:111936.183 One child process died (PID:59034,exitcode/signal:1). Exiting ... 59033:20210924:111936.187 syncing trend data... 59033:20210924:111936.187 syncing trend data done 59033:20210924:111936.187 Zabbix Server stopped. Zabbix 5.4.4 (revision 1765c4f1bc).
zabbix_agentd.log
971:20210920:144344.968 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 972:20210920:144444.982 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 973:20210920:144544.997 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 971:20210920:144644.011 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 972:20210920:144744.025 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 973:20210920:144844.039 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 971:20210920:144944.054 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 971:20210920:145044.069 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 973:20210920:145144.083 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 971:20210920:145244.097 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 973:20210920:145344.111 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 973:20210920:145444.124 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 973:20210920:145544.139 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 973:20210920:145644.152 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 973:20210920:145744.167 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 973:20210920:145844.183 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 971:20210920:145953.438 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 972:20210920:150053.453 failed to accept an incoming connection: from 127.0.0.1: TLS connections are not allowed 974:20210920:150229.122 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused) 966:20210920:153024.771 Got signal [signal:15(SIGTERM),sender_pid:102925,sender_uid:99 7,reason:0]. Exiting ... 966:20210920:153024.776 Zabbix Agent stopped. Zabbix 5.4.4 (revision 1765c4f1bc). 980:20210920:153103.959 Starting Zabbix Agent [Zabbix server]. Zabbix 5.4.4 (revision 1765c4f1bc). 980:20210920:153103.962 **** Enabled features **** 980:20210920:153103.962 IPv6 support: YES 980:20210920:153103.962 TLS support: YES 980:20210920:153103.962 ************************** 980:20210920:153103.962 using configuration file: /etc/zabbix/zabbix_agentd.conf 980:20210920:153103.969 agent #0 started [main process] 985:20210920:153103.984 agent #2 started[listener #1] 984:20210920:153103.993 agent #1 started [collector] 986:20210920:153104.007 agent #3 started[listener #2] 987:20210920:153104.008 agent #4 started[listener #3] 988:20210920:153104.011 agent #5 started [active checks #1] 988:20210920:153104.046 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused) 980:20210920:155204.574 Got signal [signal:15(SIGTERM),sender_pid:2208,sender_uid:997, reason:0]. Exiting ... 980:20210920:155204.576 Zabbix Agent stopped. Zabbix 5.4.4 (revision 1765c4f1bc). 982:20210920:155400.709 Starting Zabbix Agent [Zabbix server]. Zabbix 5.4.4 (revision 1765c4f1bc). 982:20210920:155400.710 **** Enabled features **** 982:20210920:155400.710 IPv6 support: YES 982:20210920:155400.710 TLS support: YES 982:20210920:155400.710 ************************** 982:20210920:155400.711 using configuration file: /etc/zabbix/zabbix_agentd.conf 982:20210920:155400.711 agent #0 started [main process] 985:20210920:155400.772 agent #2 started[listener #1] 986:20210920:155400.773 agent #3 started[listener #2] 984:20210920:155400.774 agent #1 started [collector] 987:20210920:155400.775 agent #4 started[listener #3] 988:20210920:155400.784 agent #5 started [active checks #1] 988:20210920:155400.789 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused) 982:20210920:185958.506 Got signal [signal:15(SIGTERM),sender_pid:8588,sender_uid:997, reason:0]. Exiting ... 982:20210920:185958.508 Zabbix Agent stopped. Zabbix 5.4.4 (revision 1765c4f1bc). 974:20210920:190449.616 Starting Zabbix Agent [Zabbix server]. Zabbix 5.4.4 (revision 1765c4f1bc). 974:20210920:190449.620 **** Enabled features **** 974:20210920:190449.621 IPv6 support: YES 974:20210920:190449.621 TLS support: YES 974:20210920:190449.621 ************************** 974:20210920:190449.621 using configuration file: /etc/zabbix/zabbix_agentd.conf 974:20210920:190449.621 agent #0 started [main process] 975:20210920:190449.643 agent #1 started [collector] 976:20210920:190449.645 agent #2 started[listener #1] 977:20210920:190449.649 agent #3 started[listener #2] 978:20210920:190449.652 agent #4 started[listener #3] 979:20210920:190449.656 agent #5 started [active checks #1] 979:20210920:190449.734 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused) 953:20210923:102911.054 Starting Zabbix Agent [Zabbix server]. Zabbix 5.4.4 (revision 1765c4f1bc). 953:20210923:102911.060 **** Enabled features **** 953:20210923:102911.060 IPv6 support: YES 953:20210923:102911.060 TLS support: YES 953:20210923:102911.060 ************************** 953:20210923:102911.060 using configuration file: /etc/zabbix/zabbix_agentd.conf 953:20210923:102911.065 agent #0 started [main process] 958:20210923:102911.083 agent #4 started[listener #3] 959:20210923:102911.084 agent #5 started [active checks #1] 957:20210923:102911.085 agent #3 started[listener #2] 956:20210923:102911.085 agent #2 started[listener #1] 955:20210923:102911.087 agent #1 started [collector] 959:20210923:102911.117 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused) 953:20210923:103918.829 Got signal [signal:15(SIGTERM),sender_pid:1209,sender_uid:997, reason:0]. Exiting ... 953:20210923:103918.832 Zabbix Agent stopped. Zabbix 5.4.4 (revision 1765c4f1bc). 970:20210923:104004.018 Starting Zabbix Agent [Zabbix server]. Zabbix 5.4.4 (revision 1765c4f1bc). 970:20210923:104004.047 **** Enabled features **** 970:20210923:104004.047 IPv6 support: YES 970:20210923:104004.047 TLS support: YES 970:20210923:104004.047 ************************** 970:20210923:104004.047 using configuration file: /etc/zabbix/zabbix_agentd.conf 970:20210923:104004.048 agent #0 started [main process] 972:20210923:104004.060 agent #1 started [collector] 973:20210923:104004.076 agent #2 started[listener #1] 976:20210923:104004.088 agent #5 started [active checks #1] 975:20210923:104004.089 agent #4 started[listener #3] 974:20210923:104004.093 agent #3 started[listener #2] 976:20210923:104004.136 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused)
Danke schon mal
