Estou com o sequinte problema quando tento dar start no serviço do orabbix acontece o sequinte erro:
[root@zabbix conf]# /etc/init.d/orabbix start
Starting Orabbix service:
[root@zabbix conf]# Stopping
java.lang.Exception: ERROR on main - Connections is empty
at com.smartmarmot.orabbix.Orabbixmon.run(Orabbixmon. java:101)
at com.smartmarmot.orabbix.bootstrap.main(bootstrap.j ava:50)
LOG:
2012-04-16 12:36:16,626 [main] INFO Orabbix - Starting Orabbix Version 1.2.3
2012-04-16 12:36:16,654 [main] INFO Orabbix - Orabbix started with pid:7345
2012-04-16 12:36:16,654 [main] INFO Orabbix - PidFile -> ./logs/orabbix.pid
2012-04-16 12:36:16,819 [main] INFO Orabbix - DB Pool created: org.apache.commons.dbcp.datasources.SharedPoolData Source@14d6a05e
2012-04-16 12:36:16,819 [main] INFO Orabbix - URL=jdbc
racle:thin:@dbdesenv.tcemt.gov.br:1521:dbdesenv
2012-04-16 12:36:16,819 [main] INFO Orabbix - maxPoolSize=100
2012-04-16 12:36:16,820 [main] INFO Orabbix - maxIdleSize=1
2012-04-16 12:36:16,820 [main] INFO Orabbix - maxIdleTime=1800000ms
2012-04-16 12:36:16,820 [main] INFO Orabbix - poolTimeout=100
2012-04-16 12:36:16,820 [main] INFO Orabbix - timeBetweenEvictionRunsMillis=-1
2012-04-16 12:36:16,820 [main] INFO Orabbix - numTestsPerEvictionRun=3
2012-04-16 12:36:19,158 [main] ERROR Orabbix - Error on Configurator for database dbdesenv -->ORA-01017: senha/nome do usuário inválido; log-on negado
2012-04-16 12:36:19,158 [main] INFO Orabbix - This Database dbdesenv removed
2012-04-16 12:36:19,159 [main] ERROR Orabbix - ERROR on main - Connections is empty
[root@zabbix logs]# java -version
java version "1.6.0_31"
Java(TM) SE Runtime Environment (build 1.6.0_31-b04)
Java HotSpot(TM) 64-Bit Server VM (build 20.6-b01, mixed mode)
Já testei o usuario no banco logando direto no banco e funcionou a conexão.
Alguem tem alguma sugestão para solução deste problema.
LOG:
racle:thin:@dbdesenv.tcemt.gov.br:1521:dbdesenv2012-04-16 12:36:16,819 [main] INFO Orabbix - maxPoolSize=100
