Hola.
Tengo instalada la ultima version de zabbix.
Estoy tratando de monitorear server linux debian por snmpv3 y tengo este problema
Como ven es el hostname 4.
Tengo 2 host mas agregados y no hay problema, con los mismos OIDs.
Clono uno de de los que andan bien y empieza a hacer esto, agrego de cero y tambien
Busque informacion sobre errores snmpv3 en zabbix pero no hay respuestas.
Por snmpwalk no hay problema, las consultas andan siempre
Alguien tiene una solucion para esto? o estoy monitoreando mal?
3144:20130607:112001.086 SNMP item [wan1u] on host [4] failed: first network error, wait for 15 seconds
3147:20130607:112016.031 resuming SNMP checks on host [4]: connection restored
3144:20130607:112022.162 SNMP item [wan2d] on host [4] failed: first network error, wait for 15 seconds
3142:20130607:112023.542 SNMP item [wan2u] on host [4] failed: first network error, wait for 15 seconds
3147:20130607:112136.064 resuming SNMP checks on host [4]: connection restored
3146:20130607:112216.347 SNMP item [PD] on host [4] failed: first network error, wait for 15 seconds
3143:20130607:112217.445 SNMP item [PV] on host [4] failed: first network error, wait for 15 seconds
3142:20130607:112218.985 SNMP item [SD] on host [4] failed: first network error, wait for 15 seconds
3144:20130607:112219.993 SNMP item [SV] on host [4] failed: first network error, wait for 15 seconds
3145:20130607:112221.011 SNMP item [wan1d] on host [4] failed: first network error, wait for 15 seconds
3147:20130607:112236.213 resuming SNMP checks on host [4]: connection restored
