Problemas encolados en Zabbix!!!!
  • JadenGomes2
    • Aug 2019
    Buenos días,
    Tenemos un problema en la cola de zabbix, en uno de los proxys que tenemos distribuidos observamos que se quedan encolados en el campo de 1-5 minutos unos 2500-3000 items, hemos revisado los logs de zabbix y no encontramos ningún error, también hemos revisado los pollers y tienen los datos dentro de los valores normales: (Añado un trozo de la información extraída)
    25837 ? S 0:01 /usr/sbin/zabbix_proxy: vmware collector #32 [updated 0, removed 0 VMware services in 0.000008 sec, idle 5 sec]
    25838 ? S 0:01 /usr/sbin/zabbix_proxy: vmware collector #33 [updated 0, removed 0 VMware services in 0.000022 sec, idle 5 sec]
    25839 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #34 [updated 0, removed 0 VMware services in 0.000009 sec, idle 5 sec]
    25840 ? S 0:01 /usr/sbin/zabbix_proxy: vmware collector #35 [updated 0, removed 0 VMware services in 0.000021 sec, idle 5 sec]
    25841 ? S 0:01 /usr/sbin/zabbix_proxy: vmware collector #36 [updated 0, removed 0 VMware services in 0.000007 sec, idle 5 sec]
    25842 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #37 [updated 0, removed 0 VMware services in 0.000027 sec, idle 5 sec]
    25843 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #38 [updated 0, removed 0 VMware services in 0.000025 sec, idle 5 sec]
    25844 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #39 [updated 0, removed 0 VMware services in 0.000009 sec, idle 5 sec]
    25845 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #40 [updated 0, removed 0 VMware services in 0.000012 sec, idle 5 sec]
    25846 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #41 [updated 0, removed 0 VMware services in 0.000009 sec, idle 5 sec]
    25847 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #42 [updated 0, removed 0 VMware services in 0.000023 sec, idle 5 sec]
    25848 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #43 [updated 0, removed 0 VMware services in 0.000009 sec, idle 5 sec]
    25849 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #44 [updated 0, removed 0 VMware services in 0.000029 sec, idle 5 sec]
    25850 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #45 [updated 0, removed 0 VMware services in 0.000026 sec, idle 5 sec]
    25851 ? S 0:01 /usr/sbin/zabbix_proxy: vmware collector #46 [updated 0, removed 0 VMware services in 0.000022 sec, idle 5 sec]
    25852 ? S 0:01 /usr/sbin/zabbix_proxy: vmware collector #47 [updated 0, removed 0 VMware services in 0.000015 sec, idle 5 sec]
    25853 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #48 [updated 0, removed 0 VMware services in 0.000016 sec, idle 5 sec]
    25854 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #49 [updated 0, removed 0 VMware services in 0.000017 sec, idle 5 sec]
    25855 ? S 0:00 /usr/sbin/zabbix_proxy: vmware collector #50 [updated 0, removed 0 VMware services in 0.000008 sec, idle 5 sec]
    25856 ? S 0:00 /usr/sbin/zabbix_proxy: task manager [processed 0 task(s) in 0.000302 sec, idle 5 sec]
    25857 ? S 0:00 /usr/sbin/zabbix_proxy: poller #1 [got 0 values in 0.000010 sec, idle 1 sec]
    25858 ? S 0:00 /usr/sbin/zabbix_proxy: poller #2 [got 0 values in 0.000008 sec, idle 1 sec]
    25859 ? S 0:00 /usr/sbin/zabbix_proxy: poller #3 [got 0 values in 0.000009 sec, idle 1 sec]
    25860 ? S 0:00 /usr/sbin/zabbix_proxy: poller #4 [got 0 values in 0.000016 sec, idle 1 sec]
    25861 ? S 0:00 /usr/sbin/zabbix_proxy: poller #5 [got 0 values in 0.000011 sec, idle 1 sec]
    25862 ? S 0:00 /usr/sbin/zabbix_proxy: poller #6 [got 0 values in 0.000009 sec, idle 1 sec]
    25863 ? S 0:00 /usr/sbin/zabbix_proxy: poller #7 [got 0 values in 0.000008 sec, idle 1 sec]
    25864 ? S 0:00 /usr/sbin/zabbix_proxy: poller #8 [got 0 values in 0.000019 sec, idle 1 sec]
    25865 ? S 0:00 /usr/sbin/zabbix_proxy: poller #9 [got 0 values in 0.000008 sec, idle 1 sec]
    25866 ? S 0:00 /usr/sbin/zabbix_proxy: poller #10 [got 0 values in 0.000009 sec, idle 1 sec]
    25867 ? S 0:00 /usr/sbin/zabbix_proxy: poller #11 [got 1 values in 0.041363 sec, idle 1 sec]
    25868 ? S 0:00 /usr/sbin/zabbix_proxy: poller #12 [got 0 values in 0.000008 sec, idle 1 sec]
    25869 ? S 0:00 /usr/sbin/zabbix_proxy: poller #13 [got 0 values in 0.000009 sec, idle 1 sec]
    25870 ? S 0:01 /usr/sbin/zabbix_proxy: poller #14 [got 15 values in 0.013894 sec, idle 1 sec]
    25871 ? S 0:00 /usr/sbin/zabbix_proxy: poller #15 [got 0 values in 0.000008 sec, idle 1 sec]
    25872 ? S 0:00 /usr/sbin/zabbix_proxy: poller #16 [got 0 values in 0.000016 sec, idle 1 sec]
    25873 ? S 0:00 /usr/sbin/zabbix_proxy: poller #17 [got 0 values in 0.000008 sec, idle 1 sec]
    25874 ? S 0:00 /usr/sbin/zabbix_proxy: poller #18 [got 0 values in 0.000009 sec, idle 1 sec]
    25875 ? S 0:00 /usr/sbin/zabbix_proxy: poller #19 [got 0 values in 0.000011 sec, idle 1 sec]
    25876 ? S 0:00 /usr/sbin/zabbix_proxy: poller #20 [got 0 values in 0.000008 sec, idle 1 sec]
    25877 ? S 0:00 /usr/sbin/zabbix_proxy: poller #21 [got 0 values in 0.000009 sec, idle 1 sec]
    25878 ? S 0:00 /usr/sbin/zabbix_proxy: poller #22 [got 1 values in 0.047750 sec, idle 1 sec]
    25879 ? S 0:00 /usr/sbin/zabbix_proxy: poller #23 [got 0 values in 0.000010 sec, idle 1 sec]
    25880 ? S 0:00 /usr/sbin/zabbix_proxy: poller #24 [got 0 values in 0.000009 sec, idle 1 sec]
    25881 ? S 0:00 /usr/sbin/zabbix_proxy: poller #25 [got 0 values in 0.000009 sec, idle 1 sec]
    25882 ? S 0:00 /usr/sbin/zabbix_proxy: poller #26 [got 0 values in 0.000008 sec, idle 1 sec]
    25883 ? S 0:00 /usr/sbin/zabbix_proxy: poller #27 [got 0 values in 0.000018 sec, idle 1 sec]
    25884 ? S 0:00 /usr/sbin/zabbix_proxy: poller #28 [got 0 values in 0.000028 sec, idle 1 sec]
    No encontramos nada fuera de lo común en los registros del proxy, pero observamos que se nos quedan encolados muchos items entre los rangos de 1-5 minutos.
    Alguna idea de porque puede estar pasando?
  • Maurizio.Marchioro
    • Apr 2018
    Hola, que tipos de items tenéis definidos? Tienes monitorizados los propios Proxies? Intenta aumentar el nivel de log del proxy para tratar de conseguir mas detalles.
    • Hernandes Martins
      • Apr 2011
      • 901
      cual version ?
      __
      Att.
      Skype: hernandss
      Telegram: @MrHernandes
      Español
      Português
