Estou com um pequeno problema no meu zabbix. O zabbix server não consegue se conectar ao banco de dados. Mostra o seguinte erro no log:
root@ZABBIX:/etc/zabbix# tail -f /var/log/zabbix/zabbix_server.log
12811:20171016:102542.658 Cannot connect to the database. Exiting...
12814:20171016:102542.659 Cannot connect to the database. Exiting...
12805:20171016:102542.659 Cannot connect to the database. Exiting...
12825:20171016:102542.659 Cannot connect to the database. Exiting...
12526:20171016:102542.659 One child process died (PID:12700,exitcode/signal:1). Exiting ...
12526:20171016:102544.683 syncing history data...
12526:20171016:102544.683 syncing history data done
12526:20171016:102544.683 syncing trend data...
12526:20171016:102544.683 syncing trend data done
12526:20171016:102544.683 Zabbix Server stopped. Zabbix 3.2.7 (revision 70298).
Se alguém puder ajudar a reverter esta situação...
Obrigado =D
Obrigado =D
