icmppingsec con macros
  • rafalcaide
    • Feb 2019
    Hola, tengos host configurados en zabbix con varias interfaces con distinta ip, tengo creado un item icmppingsec con los valores por defecto y monitoriza la interfaz 1, quiero crear otro para monitorizar la interfaz 2, sin embargo no soy de capaz de configurarlo para que mediante macros consulte la interfaz correspondiente.
    He intentado usar {HOST.IP2} ó {HOST.CONN2} sin embargo siempre obtengo el mismo mensaje en el log:
    error reason for "hostname:icmppingsec[{HOST.IP2},3,3000,24,1000,avg]" changed: fping failed: {HOST.IP2}: Name or service not known
    Gracias, un saludo.
  • Hernandes Martins
    • Apr 2011
    • 901
    Hola amigo
    Mira,
    INDEXED MACROS
    The indexed macro syntax of {MACRO<1-9>} is limited to the context of trigger expressions. It can be used to reference hosts in the order in which they appear in the expression. Macros like {HOST.IP1}, {HOST.IP2}, {HOST.IP3} will resolve to the IP of the first, second and third host in the trigger expression (providing the trigger expression contains those hosts).
    Additionally the {HOST.HOST<1-9>} macro is also supported within the {host:key.func(param)} macro in graph names. For example, {{HOST.HOST2}:key.func()} in the graph name will refer to the host of the second item in the graph
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • markfree
      • Apr 2019
      • 874
      ¿Intentó utilizar la macro {HOST.CONN} seleccionando una interfaz específica?
      Ejemplo:
      2 items que usan la misma macro {HOST.CONN}, pero la interfaz de cada item es diferente.
      Click image for larger version  Name:	KEYS.PNG Views:	0 Size:	9.8 KB ID:	423820
      Click image for larger version  Name:	interface1.PNG Views:	0 Size:	4.7 KB ID:	423821Click image for larger version  Name:	interface2.PNG Views:	0 Size:	4.7 KB ID:	423822
      Cambié el timeout para diferenciar la key.
      otra alternativa sería crear macros para el host
      Click image for larger version  Name:	macros.PNG Views:	0 Size:	4.4 KB ID:	423824
      Click image for larger version  Name:	macros_keys.PNG Views:	0 Size:	7.0 KB ID:	423823​
      el gráfico confirma que las dos interfaces son diferentes
