Erro: SNMP agent first network error, wait for 15 seconds
  • lfernandosg
    • Dec 2015
    • 90
    Pessoal,
    Estou recebendo esse erro direto no meu zabbix e as vezes ele dá alerta de icmp loss só que o equipamento destino está OK recebendo pings.
    root@zabbix3:/home/fernando# tail -f /var/log/zabbix/zabbix_server.log
    1670:20160428:061452.415 item "CCR1036-WANTEL:ifOutOctets[<pppoe-joas.1237>]" became not supported: No Such Instance currently exists at this OID
    1671:20160428:061452.415 item "CCR1036-WANTEL:ifOutErrors[<pppoe-joas.1237>]" became not supported: No Such Instance currently exists at this OID
    1671:20160428:061452.676 item "CCR1036-WANTEL:ifOperStatus[<pppoe-joas.1237>]" became not supported: No Such Instance currently exists at this OID
    1531:20160428:061459.152 resuming SNMP agent checks on host "OLT-ORLA": connection restored
    1581:20160428:061517.067 SNMP agent item "ifOutErrors[PON 3/9/1]" on host "OLT-ORLA" failed: first network error, wait for 15 seconds
    1581:20160428:061532.112 resuming SNMP agent checks on host "OLT-ORLA": connection restored
    1519:20160428:061536.947 SNMP agent item "ifOutOctets[FE 1/2/14/1]" on host "OLT-DATACENTER" failed: first network error, wait for 15 seconds
    1568:20160428:061545.034 SNMP agent item "ifOutOctets[PON 3/11/7]" on host "OLT-ORLA" failed: first network error, wait for 15 seconds
    1556:20160428:061551.067 resuming SNMP agent checks on host "OLT-DATACENTER": connection restored
    1600:20160428:061602.596 resuming SNMP agent checks on host "OLT-ORLA": connection restored
    1584:20160428:061617.408 SNMP agent item "ifInErrors[PON 1/10]" on host "OLT-ORLA" failed: first network error, wait for 15 seconds
    1571:20160428:061632.044 resuming SNMP agent checks on host "OLT-ORLA": connection restored
    O que pode ser isso?
  • Hernandes Martins
    • Apr 2011
    • 900
    Olá meu caro,
    Observe que essa coleta qu estava fazendo é do tipo SNMP, em muitos casos os equipamentos começam a recusar um determinado pool de requisiçoes snmp.
    faça alguns ajustes
    Na configuração do HOST desabilte a opção snmpbulkrequest
    Na configuração dos itens aumente o intervalo de coleta a partir de 300 segundos, preferencialmente conexões pppoe eu coloco 900 , más é uma questão de particularidade de ambiente. adeque ao seu cenário.
    Abraços
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • lfernandosg
      • Dec 2015
      • 90
      Obrigado pelo retorno.
      Acredito que seja a parte de PPPOE. Não preciso desse monitoramento dos meus concentradores. Ainda não consegui tirar esse monitoramento. Como faço?
      • Hernandes Martins
        • Apr 2011
        • 900
        Para tirar basta incluir o parametro "pppoe" em uma expressão regular para não adicionar esssas interfaces.
        Veja em Administration>>General>>Ao lado direito selecione expressões regulares e observe " Network interfaces for discovery " e crie ou adicione expressão correspondente a pppoe.
        Da uma olhada aqui no manual.
        Abraços
        __
        Att.
        Skype: hernandss
        Español
        Português
        • lfernandosg
          • Dec 2015
          • 90
          Abraços
          Seria essa regra?
          • lfernandosg
            • Dec 2015
            • 90
            Originally posted by lfernandosg
            Seria essa regra?
            Atualizando, coloquei o filtro do template:
            {#SNMPVALUE} @pppoe
            e mesmo assim ainda continua pegando informações das interfaces pppoe
            15482:20160507:044615.562 item "CCR1009-WANTEL:ifInErrors[<pppoe-marialurdes.santos>]" became not supported: No Such Instance currently exists at this OID
            15489:20160507:044617.569 item "CCR1009-WANTEL:ifAdminStatus[<pppoe-marialurdes.santos>]" became not supported: No Such Instance currently exists at this OID
            15489:20160507:044617.570 item "CCR1009-WANTEL:ifInOctets[<pppoe-marialurdes.santos>]" became not supported: No Such Instance currently exists at this OID
            15483:20160507:044618.576 item "CCR1009-WANTEL:ifOutErrors[<pppoe-marialurdes.santos>]" became not supported: No Such Instance currently exists at this OID
            15488:20160507:044636.612 item "CCR1009-WANTEL:ifOutOctets[<pppoe-marialurdes.santos>]" became not supported: No Such Instance currently exists at this OID
            15484:20160507:044636.659 item "CCR1009-WANTEL:ifOperStatus[<pppoe-marialurdes.santos>]" became not supported: No Such Instance currently exists at this OID
            15371:20160507:044655.837 SNMP agent item "ifOutOctets[FE 2/6/1/1]" on host "OLT-ORLA" failed: first network error, wait for 15 seconds
            • Hernandes Martins
              • Apr 2011
              • 900
              Você criou uma nova expressão regular ou adicionou o pppoe em uma expressão regular ?
              __
              Att.
              Skype: hernandss
              Español
              Português
              • lfernandosg
                • Dec 2015
                • 90
                Olha o print mais acima...criei um nova e coloquei o filtro: {#SNMPVALUE} @pppoe no template.
                • rmborges3_sp
                  • May 2016
                  &quot;failed: first network error, wait for 15 seconds&quot;
                  Amigos, estou com o mesmo problema. Segue:
                  "SNMP agent item "ifInErrors[X0 (LAN)]" on host "XXXXX" failed: first network error, wait for 15 seconds"
                  "resuming SNMP agent checks on host "XXXXX": connection restored"
                  Até já alterei o intervalo para 300 segundos porém o "erro" persiste. Estou monitorando as NIC de um SonicWALL.
                  Pode ser comunicação entre o Zbx X SonicWALL ?
                  • Hernandes Martins
                    • Apr 2011
                    • 900
                    Olá meu caro,
                    E observe o comportamento.
                    __
                    Att.
                    Skype: hernandss
                    Español
                    Português
                    • lfernandosg
                      • Dec 2015
                      • 90
                      Olá, sou novo no zabbix. Procurei e não encontrei. Poderia me passar o local aonde fica essa configuração?
                      • Jefte
                        • Oct 2015
                        • 207
                        Seria em portugues " Usar requisições em lote " desmarque essa caixa nos hosts que desejar !
                        • Hernandes Martins
                          • Apr 2011
                          • 900
                          Olá
                          Meu caro da uma olhada no print de tela.
                          Abraços
                          __
                          Att.
                          Skype: hernandss
                          Español
                          Português
                          • lfernandosg
                            • Dec 2015
                            • 90
                            Olá, fiz isso. parou por um tempo e depois voltou mesmo alterando o intervalo e requisições em lote.
