Zabbix Inativo e Erro no Banco de Dados
  • Wesbonf
    • Aug 2023
    Meu Zabbix está apresentando dois erros, a princípio, erro relacionado ao servidor, e o banco de dados.
    Em tail -f /var/log/zabbix/zabbix_server.log está apresentado estes avisos:
    1405:20230801:105846.101 Unsupported DB! MariaDB version is 110002 which is higher than maximum of 101 199
    1405:20230801:105846.103
    1405:20230801:105846.104 Unable to start Zabbix server due to unsupported MariaDB database version (11 .00.02).
    1405:20230801:105846.104 Must not be higher than (10.11.xx).
    1405:20230801:105846.104 Use of supported database version is highly recommended.
    1405:20230801:105846.104 Override by setting AllowUnsupportedDBVersions=1 in Zabbix server configurati on file at your own risk.
    1408:20230801:105858.338 Starting Zabbix Server. Zabbix 6.0.19 (revision 998f8649378).
    1408:20230801:105858.339 ****** Enabled features ******
    1408:20230801:105858.340 SNMP monitoring: YES
    1408:20230801:105858.341 IPMI monitoring: YES
    1408:20230801:105858.341 Web monitoring: YES
    1408:20230801:105858.341 VMware monitoring: YES
    1408:20230801:105858.341 SMTP authentication: YES
    1408:20230801:105858.341 ODBC: YES
    1408:20230801:105858.341 SSH support: YES
    1408:20230801:105858.341 IPv6 support: YES
    1408:20230801:105858.341 TLS support: YES
    1408:20230801:105858.341 ******************************
    1408:20230801:105858.341 using configuration file: /etc/zabbix/zabbix_server.conf
    1408:20230801:105858.352 Unsupported DB! MariaDB version is 110002 which is higher than maximum of 101199
    1408:20230801:105858.353
    1408:20230801:105858.354 Unable to start Zabbix server due to unsupported MariaDB database version (11.00.02).
    1408:20230801:105858.354 Must not be higher than (10.11.xx).
    1408:20230801:105858.355 Use of supported database version is highly recommended.
    1408:20230801:105858.355 Override by setting AllowUnsupportedDBVersions=1 in Zabbix server configuration file at your own risk.
  • mfortes
    • Oct 2019
    • 418
    Pimeiro erro, sobre o zabbix estar rodando... você precisa configurar o ip do servidor e as demais configurações la no /etc/zabbix do front-end.
    O erro do banco de dados se resume ao erro "Unsupported DB! MariaDB version is 110002 which is higher than maximum of 101199", ou seja, reinsta-le o banco de dados na versão suportada que ira funcionar.
    Michael R. Fortes
    Linkedin: Mike Fortes
    Medium: mromeiro-f
