Monitorando Fans, fontes entre outros Cisco
  • lfernandosg
    • Dec 2015
    • 90
    Pessoal,
    Estou usando template para o cisco nexus 9000 só que a parte do auto busca para supply, fan, temperatura não está funcionando.
    Fiz todas configurações com mapeamento de valores, coloquei as mibs dentro da /var/libs/mibs, alterei snmp.conf apontando as mibs como abaixo e mesmo assim ele não captura.
    cat /etc/snmp/snmp.conf
    # As the snmp packages come without MIB files due to license reasons, loading
    # of MIBs is disabled by default. If you added the MIBs you can reenable
    # loading them by commenting out the following line.
    #mibs :
    #mibs +ALL
    mibs +CISCO-ENTITY-SENSOR-MIB
    mibs +CISCO-ENVMON-MIB
    mibs +CISCO-MEMORY-POOL-MIB
    o que peciso fazer para funcionar e o zabbix coletar essas informações?
  • lfernandosg
    • Dec 2015
    • 90
    Vi hoje no log que aparece isso:
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonVoltageStatusIndex ::= { ciscoEnvMonVoltageStatusEntry 1 }
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonMIBNotifications ::= { ciscoEnvMonMIBNotificationPrefix 0 }
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonMIBMiscNotifGroup ::= { ciscoEnvMonMIBGroups 6 }
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonStatChangeNotifGroup ::= { ciscoEnvMonMIBGroups 5 }
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonMIBNotifGroup ::= { ciscoEnvMonMIBGroups 4 }
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonEnableStatChangeGroup ::= { ciscoEnvMonMIBGroups 3 }
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonMIBGroupRev ::= { ciscoEnvMonMIBGroups 2 }
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonMIBGroup ::= { ciscoEnvMonMIBGroups 1 }
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonSupplyStatusEntry ::= { ciscoEnvMonSupplyStatusTable 1 }
    Cannot adopt OID in CISCO-ENVMON-MIB: ciscoEnvMonTemperatureStatusEntry ::= { ciscoEnvMonTemperatureStatusTable 1 }
    • Hernandes Martins
      • Apr 2011
      • 901
      Olá meu cari
      Já tentou validar se essas oids realmente existem na arvore snmp do equipamento CISCO ?
      No site da cisco tem essas informações sobre essas mibs, da uma pesquisada lá.
      Abraços
      __
      Att.
      Skype: hernandss
      Telegram: @MrHernandes
      Español
      Português
      • lfernandosg
        • Dec 2015
        • 90
        Olá meu cari
        Abraços
        tem sim!!
        Quando executo o comando do scritp que está junto com o template:
        sh /usr/lib/zabbix/externalscripts/echo.something
        O erro e OID para mas ele não coleta. Não sei o que está faltando.
        • cros
          • Jul 2017
          • 87
          vixi , faz tempo esse paranaue, kkkk, bom, entao mais vc nao descomentou este paranaue mano.
          #mibs +ALL
          e apos isso se nao der um restart no zabbix_server nao funciona d cara.
