Ayuda para crear iniciador con función "Count"
  • steck
    • Aug 2024
    • 11
    Estimados:
    Necesito crear un Trigger basado en SNMP que cuente en un router Huawei la cantidad de mpls-lsp down.
    mplsLspInfoState .1.3.6.1.4.1.2636.3.2.5.1.2
    steck@proxy3:~$ snmpwalk -v 2c -c xxxxx 10.27.34.11 1.3.6.1.4.1.2636.3.2.5.1.2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.97.116.102.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.97.116.102.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.99.99.112.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.99.99.112.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.99.104.105.111.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.99.104.105.111.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.99.111.121.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.99.111.121.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.99.112.112.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.99.112.112.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.105.110.100.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.105.110.100.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.105.113.113.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.105.113.113.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.108.102.108.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.108.102.108.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.109.109.116.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.109.109.116.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.112.109.116.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.112.109.116.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.114.110.103.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.114.110.103.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.115.97.110.95.103.101.110 = INTEGER: 3
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.115.97.110.95.115.105.103 = INTEGER: 3
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.115.109.116.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.115.109.116.95.115.105.103 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.115.114.110.95.103.101.110 = INTEGER: 2
    iso.3.6.1.4.1.2636.3.2.5.1.2.114.49.112.100.118.95 .114.49.115.114.110.95.115.105.103 = INTEGER: 2​
    Los monitores son reconocidos y entregan el valor del status, 2=up y 3=down.
    Necesito construir un Trigger que cuente la cantidad de mpls-lsp de un host que se encuentren en status=3. Con la función "count" entiendo que uno puede contar la cantidad de valores hacia atrás sobre un unico índice snmp que cumplen cierto valor. En este caso sería contar la cantidad de mpls-lsp-status=3 de la última medidad. Sería algo parecido a contar cuantas interfaces hay down en un switch en la última medición. He intentado lo siguiente, pero no me resulta.
    Muchas gracias
  • markfree
    • Apr 2019
    • 875
    Mira las funciones agregadas.
    Creo que puedes usar la función "count" con la función "foreach".
    Talvez algo como esto:
    count(last_foreach(/Juniper-MPLS-LSP/mpls.lsp.status2[1.3.6.1.4.1.2636.3.2.5.1.2.*]),"eq",3)<>0
