Probleme Vmware 6.7
  • barto_95
    • Nov 2018
    • 19
    Probleme Vmware 6.7
    Bonjour,
    j'essais de superviser mon cluster Vmware 6.7 mais impossible j'ai des messages d'erreur
    j'ai suivi plusieurs tuto, utiliser plusieurs template différente mais j'ai a chaque fois un message d'erreur
    Création d'un compte local ( et au cas ou un utilisateur SSO) avec les droit en lecture seul et propager du VCSA vers les ESXI
    Lorsque j'utilise le template d'origine j'ai des message d'erreur du type :
    10876:20190621:165413.667 item "esxi-1.local.fr:vmware.hv.maxcpu" became not supported: Cannot evaluate expression: "Cannot evaluate function "last()": not enough data.".
    10873:20190621:165414.669 item "esxi-1.local.fr:vmware.hv.memory.size.ballooned[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10874:20190621:165415.669 item "esxi-1.local.fr:vmware.hv.memory.used[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10874:20190621:165416.676 item "esxi-1.local.fr:vmware.hv.network.in[{$URL},{HOST.HOST},bps]" became not supported: Cannot complete login due to an incorrect user name or password.
    10874:20190621:165417.681 item "esxi-1.local.fr:vmware.hv.network.out[{$URL},{HOST.HOST},bps]" became not supported: Cannot complete login due to an incorrect user name or password.
    10876:20190621:165418.687 item "esxi-1.local.fr:vmware.hv.status[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10875:20190621:165503.736 item "esxi-1.local.fr:vmware.hv.cpu.usage[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10882:20190621:170030.700 Error of query maxQueryMetrics: Permission to perform this operation was denied..
    10873:20190621:170037.381 item "vcsa.local.fr:vmware.hv.maxcpu" became not supported: Cannot evaluate expression: "Cannot evaluate function "last()": not enough data.".
    10873:20190621:170038.701 item "vcsa.local.fr:vmware.hv.memory.size.ballooned[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10873:20190621:170039.858 item "vcsa.local.fr:vmware.hv.memory.used[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10875:20190621:170041.033 item "vcsa.local.fr:vmware.hv.network.in[{$URL},{HOST.HOST},bps]" became not supported: Unknown hypervisor uuid.
    10876:20190621:170042.035 item "vcsa.local.fr:vmware.hv.network.out[{$URL},{HOST.HOST},bps]" became not supported: Unknown hypervisor uuid.
    10874:20190621:170043.075 item "vcsa.local.fr:vmware.hv.status[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10876:20190621:170127.983 item "vcsa.local.fr:vmware.hv.cpu.usage[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10883:20190621:170130.305 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    10883:20190621:170230.599 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    10874:20190621:170303.325 item "esxi-1.local.fr:vmware.hv.cluster.name[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10876:20190621:170305.326 item "esxi-1.local.fr:vmware.hv.fullname[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10873:20190621:170306.329 item "esxi-1.local.fr:vmware.hv.hw.cpu.freq[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10875:20190621:170307.330 item "esxi-1.local.fr:vmware.hv.hw.cpu.model[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10874:20190621:170308.333 item "esxi-1.local.fr:vmware.hv.hw.cpu.num[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10876:20190621:170309.335 item "esxi-1.local.fr:vmware.hv.hw.cpu.threads[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10873:20190621:170310.336 item "esxi-1.local.fr:vmware.hv.hw.memory[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10875:20190621:170311.337 item "esxi-1.local.fr:vmware.hv.hw.model[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10874:20190621:170312.342 item "esxi-1.local.fr:vmware.hv.hw.uuid[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10876:20190621:170313.343 item "esxi-1.local.fr:vmware.hv.hw.vendor[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10873:20190621:170314.346 error reason for "esxi-1.local.fr:vmware.hv.maxcpu" changed: Cannot evaluate expression: "Cannot evaluate function "last()": item "esxi-1.local.fr:vmware.hv.hw.cpu.freq[{$URL},{HOST.HOST}]" not supported.".
    10873:20190621:170320.359 item "esxi-1.local.fr:vmware.hv.uptime[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10874:20190621:170321.361 item "esxi-1.local.fr:vmware.hv.version[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10873:20190621:170322.367 item "esxi-1.local.fr:vmware.hv.vm.num[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10910:20190621:170322.688 discovery rule "esxi-1.local.fr:vmware.hv.datastore.discovery[{$URL},{HOST.HOST}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10909:20190621:170325.690 discovery rule "esxi-1.local.fr:vmware.hv.discovery[{$URL}]" became not supported: Cannot complete login due to an incorrect user name or password.
    10873:20190621:170327.374 item "vcsa.local.fr:vmware.hv.cluster.name[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10876:20190621:170329.377 item "vcsa.local.fr:vmware.hv.fullname[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10874:20190621:170330.382 item "vcsa.local.fr:vmware.hv.hw.cpu.freq[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10880:20190621:170330.795 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    10873:20190621:170331.382 item "vcsa.local.fr:vmware.hv.hw.cpu.model[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10876:20190621:170332.386 item "vcsa.local.fr:vmware.hv.hw.cpu.num[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10873:20190621:170333.389 item "vcsa.local.fr:vmware.hv.hw.cpu.threads[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10874:20190621:170334.389 item "vcsa.local.fr:vmware.hv.hw.memory[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10876:20190621:170335.392 item "vcsa.local.fr:vmware.hv.hw.model[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10873:20190621:170336.395 item "vcsa.local.fr:vmware.hv.hw.uuid[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10874:20190621:170337.397 item "vcsa.local.fr:vmware.hv.hw.vendor[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10876:20190621:170338.400 error reason for "vcsa.local.fr:vmware.hv.maxcpu" changed: Cannot evaluate expression: "Cannot evaluate function "last()": item "vcsa.local.fr:vmware.hv.hw.cpu.freq[{$URL},{HOST.HOST}]" not supported.".
    10873:20190621:170344.409 item "vcsa.local.fr:vmware.hv.uptime[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10875:20190621:170345.410 item "vcsa.local.fr:vmware.hv.version[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10874:20190621:170346.410 item "vcsa.local.fr:vmware.hv.vm.num[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10910:20190621:170346.710 discovery rule "vcsa.local.fr:vmware.hv.datastore.discovery[{$URL},{HOST.HOST}]" became not supported: Unknown hypervisor uuid.
    10884:20190621:170430.831 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    10883:20190621:170530.372 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    10883:20190621:170630.635 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    10883:20190621:170730.473 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    10883:20190621:170831.033 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    10883:20190621:170931.536 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    pour info j'arrive bien a me connecter sur la page web du VCSA + ESXI avec le compte renseigne dans les macros du template
    Merci pour votre aide
  • steve.destivelle
    • Feb 2017
    • 304
    Hello.
    est-ce que sur ton hôte tu as pensé à rajouter la MACRO {$URL} afin d'y mettre comme valeur l'adresse vers le sdk ?
    Steve
    "Estimez la taille de votre base de données Zabbix: http://tools.izi-it.io
    "Rejoignez le ZABBIX Discord francophone https://discordapp.com/invite/hvauXEQ"
    "izi-it.io / ZABBIX Certified Trainer / ZABBIX French Evangelist"
    • barto_95
      • Nov 2018
      • 19
      Oui
      macro {$URL}, {#PASSWORD}, {#USER}
      mais rien
      • steve.destivelle
        • Feb 2017
        • 304
        Attention pour user et password ceux sont des macros utilisateur et non de découverte.
        Donc {$USER} et {$PASSWORD}
        • barto_95
          • Nov 2018
          • 19
          exact
          erreur lors de mon msg
          mais c'est bien les bonnes valeur qui sont inscrit et pourtant rien ....
          • steve.destivelle
            • Feb 2017
            • 304
            Est-ce que tu peux poster l'URL que tu utilises ?
            Tu peux remplacer ton nom d'hôte par des X.
            • barto_95
              • Nov 2018
              • 19
              voici l'image de ma config
              Click image for larger version  Name:	2019-06-27_11-03-51.png Views:	1 Size:	26.6 KB ID:	381452
              J'ai test de me connecter avec le même compte sur le VCSA directement et cela fonctionne ... mais avec zabbix non
              et j'utilise le template :
              Template VM VMware
              • steve.destivelle
                • Feb 2017
                • 304
                Est-ce que tu as la possibilité de tester avec l'utilisateur root de ton esx ?
                Juste pour checker si cela vient des permissions de ton utilisateur ou pas.
                • barto_95
                  • Nov 2018
                  • 19
                  de l'esx ? j'ai coller le template sur le VCSA pas les ESXI c'est pas bon ?
                  • steve.destivelle
                    • Feb 2017
                    • 304
                    Tu veux dire Vcenter ?
                    • barto_95
                      • Nov 2018
                      • 19
                      oui template mise en place sur le VCSA (Vcenter Server Appliance)
                      j'ai fait le test avec le compte root@xxxxx meme constat
