в логах прокси Error ZBX_TCP_READ
  • ugh
    • Jun 2009
    • 296
    40579:20090812:171807 Error while receiving answer from server [ZBX_TCP_READ() failed [Interrupted system call]]
    40579:20090812:171807 Heartbeat message failed
    периодически(!) начинает валится в лог заббикс_прокси
    ни на один сетевой уровень грешить вроде не стоит
    по какой схеме прокся сообщает серверу что она жива?
    может в мускуль заноситься что-то не успевает?
  • ugh
    • Jun 2009
    • 296
    перегруженный mysql дает такой эффект
    • titov
      • Dec 2009
      • 50
      У меня похожая проблема, стаит cisco 1812, с firewall порты опубликованы, сессия установлена, а в логах zabbix:
      4701:20091223:200121 NODE 5: Sending configuration changes to master node 1 for node 5 datalen 4099628
      4701:20091223:200227 NODE 5: Unable to connect to Node [1] error: Cannot connect to [212.45.20.130:10051] [Connection timed out]
      4701:20091223:200400 NODE 5: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
      4701:20091223:200553 NODE 5: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
      4701:20091223:200748 NODE 5: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
      4701:20091223:201002 NODE 5: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
      4701:20091223:201153 NODE 5: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
      4701:20091223:201413 NODE 5: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
      4701:20091223:201607 NODE 5: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
      4701:20091223:201629 NODE 5: Sending configuration changes to master node 1 for node 5 datalen 4099628
      4701:20091223:201829 NODE 5: Error while sending data to Node [1] error: ZBX_TCP_WRITE() failed [Connection reset by peer]
      4701:20091223:202045 NODE 5: Sending configuration changes to master node 1 for node 5 datalen 4099628
      4701:20091223:204855 NODE 5: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
      4701:20091223:205123 NODE 5: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
      При этом на cisco сессия установлена...
      Established Sessions
      Session 839A4E18 (192.168.101.10:54364)=>(212.45.xx.xxx:10051) tcp SIS_OPEN
      Кто-нибудь сталкивался с такими проблемами?
      С чем это может быть связано?
