CentOS 5.4 x86_64
Zabbix Server v1.8.2 (revision 10556) (27 January 2010)
PostgreSQL 8.4.2
При импорте шаблона с графиками вылетает ошибка:
Тоже самое если просто сделать экспорт готового тимплита и этот же файл импортировать.
PostgreSQL 8.4.2
pg_query() [<a href='function.pg-query'>function.pg-query</a>]: Query failed: ERROR: invalid input syntax for type boolean: "if1" at character 104[/var/www/vhosts/zabbix/html/include/db.inc.php:408]
Error in query [SELECT DISTINCT g.* FROM graphs g WHERE ((g.graphid BETWEEN 000000000000000 AND 099999999999999)) AND 'if1'] [ERROR: invalid input syntax for type boolean: "if1" at character 104]
pg_fetch_assoc() expects parameter 1 to be resource, boolean given[/var/www/vhosts/zabbix/html/include/db.inc.php:558]
pg_free_result(): supplied argument is not a valid PostgreSQL result resource[/var/www/vhosts/zabbix/html/include/db.inc.php:560]
pg_query() [<a href='function.pg-query'>function.pg-query</a>]: Query failed: ERROR: current transaction is aborted, commands ignored until end of transaction block[/var/www/vhosts/zabbix/html/include/db.inc.php:408]
Error in query [SELECT DISTINCT h.* FROM hosts h WHERE ((h.hostid BETWEEN 000000000000000 AND 099999999999999)) AND h.status IN (0,1) AND h.host='t_switch_50_copy'] [ERROR: current transaction is aborted, commands ignored until end of transaction block]
Error in query [SELECT h.* FROM hosts h WHERE ((h.hostid BETWEEN 000000000000000 AND 099999999999999)) AND h.status=3 AND h.host='t_switch_50_copy'] [ERROR: current transaction is aborted, commands ignored until end of transaction block]
Missing items for graph "if1"
