виснет usb модем
  • john74ru
    • Jan 2014
    • 25
    виснет usb модем
    Подскажите, почему постоянно виснет usb модем?
    Zabbix 2.2.2, на виртуалке с Debian
    Как отправлять логи, так в логе ошибки, далее помогает перезагрузка и смс начинают валиться.
    Сам сервер работает нормально, глюк только с отправкой смс.
    Вот часть лога:
    2014-03-18 07:32:28,3, Megafon-Huawei-E352: Unexpected input: ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21 ^RSSI:21
    2014-03-18 14:35:01,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:35:11,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:35:18,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:35:27,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:35:37,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:35:46,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:35:55,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:36:04,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:36:14,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:36:24,3, Megafon-Huawei-E352: write_to_modem: error 5: Input/output error
    2014-03-18 14:36:33,3, Megafon-Huawei-E352: Couldn't open serial port /dev/ttyUSB1, error: No such file or directory, waiting 30 sec.
    2014-03-18 14:37:03,3, Megafon-Huawei-E352: Cannot open serial port /dev/ttyUSB1, error: No such file or directory
    2014-03-18 14:37:03,3, Megafon-Huawei-E352: Modem is not ready to answer commands (Timeouts: 0)
    2014-03-18 14:37:03,3, Megafon-Huawei-E352: Couldn't open serial port /dev/ttyUSB1, error: No such file or directory, waiting 30 sec.
    2014-03-18 14:37:33,3, Megafon-Huawei-E352: Cannot open serial port /dev/ttyUSB1, error: No such file or directory
    2014-03-18 14:37:33,2, Megafon-Huawei-E352: Modem handler 0 terminated. PID: 1784, was started 14-03-18 07:32:28.
    2014-03-18 14:43:43,2, smsd: Smsd mainprocess is awaiting the termination of all modem handlers. PID: 1783.
    2014-03-18 14:43:43,2, smsd: Smsd mainprocess terminated. PID 1783, was started 14-03-18 07:32:28.
    2014-03-18 14:44:48,2, smsd: Smsd v3.1.11 started.
    2014-03-18 14:44:48,2, smsd: Running as smsd:dialout.
    2014-03-18 14:44:48,4, smsd: File mode creation mask: 022 (0644, rw-r--r--).
    2014-03-18 14:46:07,3, Megafon-Huawei-E352: Unexpected input: ^RSSI:21
    2014-03-18 14:47:04,3, Megafon-Huawei-E352: Unexpected input: ^RSSI:21
    2014-03-18 14:47:31,3, Megafon-Huawei-E352: Unexpected input: ^RSSI:18
    2014-03-18 14:47:37,3, Megafon-Huawei-E352: Unexpected input: ^RSSI:18
