vfs.fs.inode issues
  • Janice21
    • Mar 2019
    vfs.fs.inode issues
    For some reason, on some servers, gentoo returns nan. On others, everything is ok. Who can met such problem?
    I met with a problem in vfs.fs.inode.
    I.e. In some servers gentoo returns to nan, i don't know the reason behind this issue. Has anyone noticed this before? feedbacks are welcomed.
    Normal Code-
    20233:20090408:195529 Requested [vfs.fs.inode[/,pfree]] 20233:20090408:195529 Sending back [93.618993]
    Isuue Code-
    16294:20090408:195843 Requested [vfs.fs.inode[/,pfree]] 16294:20090408:195843 Sending back [nan]
  • Kos
    • Aug 2015
    • 3461
    Maybe, filesystems differ? For example, on my SUSE Linux servers Zabbix agents return "ZBX NOTSUPPORTED" for vfs.fs.inode metric where filesystem is Btrfs. If the filesystem is Ext2/Ext3/Ext4/XFS/ReiserFS - all is OK.
    • Janice21
      • Mar 2019
      hey Kos thankyou so much for making me understand all this. I am glad that you cleared my doubts, hi fi and thanks for my side
