404 Not Found
  • andreyussur
    • Jun 2014
    404 Not Found
    Первый раз установил zabbix. В логе при запуске вроде как все нормально.
     1419:20140609:180301.708 Starting Zabbix Server. Zabbix 2.2.3 (revision 44105$
      1419:20140609:180301.708 ****** Enabled features ******
      1419:20140609:180301.708 SNMP monitoring:           YES
      1419:20140609:180301.708 IPMI monitoring:            NO
      1419:20140609:180301.708 WEB monitoring:            YES
      1419:20140609:180301.708 VMware monitoring:          NO
      1419:20140609:180301.708 Jabber notifications:       NO
      1419:20140609:180301.708 Ez Texting notifications:  YES
      1419:20140609:180301.708 ODBC:                       NO
      1419:20140609:180301.708 SSH2 support:               NO
      1419:20140609:180301.708 IPv6 support:              YES
      1419:20140609:180301.708 ******************************
      1419:20140609:180301.708 using configuration file: /usr/local/etc/zabbix_serv$
      1419:20140609:180301.761 current database version (mandatory/optional): 02020$
      1419:20140609:180301.761 required mandatory version: 02020000
      1422:20140609:180301.780 server #2 started [db watchdog #1]
      1429:20140609:180301.784 server #9 started [trapper #1]
      1430:20140609:180301.784 server #10 started [trapper #2]
      1431:20140609:180301.785 server #11 started [trapper #3]
      1432:20140609:180301.789 server #12 started [trapper #4]
      1421:20140609:180301.793 server #1 started [configuration syncer #1]
      1433:20140609:180301.793 server #13 started [trapper #5]
      1434:20140609:180301.795 server #14 started [icmp pinger #1]
      1435:20140609:180301.796 server #15 started [alerter #1]
      1441:20140609:180301.803 server #17 started [timer #1]
      1440:20140609:180301.804 server #16 started [housekeeper #1]
      1440:20140609:180301.804 executing housekeeper
      1419:20140609:180301.811 server #0 started [main process]
      1442:20140609:180301.812 server #18 started [http poller #1]
      1446:20140609:180301.818 server #20 started [history syncer #1]
      1449:20140609:180301.819 server #23 started [history syncer #4]
      1450:20140609:180301.819 server #24 started [escalator #1]
      1447:20140609:180301.820 server #21 started [history syncer #2]
      1448:20140609:180301.819 server #22 started [history syncer #3]
      1451:20140609:180301.820 server #25 started [proxy poller #1]
      1452:20140609:180301.820 server #26 started [self-monitoring #1]
      1440:20140609:180301.871 housekeeper [deleted 0 hist/trends, 0 items, 0 event$
      1428:20140609:180303.506 server #8 started [unreachable poller #1]
      1426:20140609:180303.507 server #6 started [poller #4]
      1424:20140609:180303.508 server #4 started [poller #2]
      1443:20140609:180303.508 server #19 started [discoverer #1]
      1423:20140609:180303.509 server #3 started [poller #1]
      1425:20140609:180303.509 server #5 started [poller #3]
      1427:20140609:180303.513 server #7 started [poller #5]
    Mysql лог почему-то не пишет (это отдельная история), но он запущен.
    netstat -tap | grep mysql
    tcp        0      0 localhost:mysql         *:*                     LISTEN      1522/mysqld
    При всем этом если зайти на ip-адрес сервера заббикса, то видна апачевская заглушка, но если добавить /zabbix то выдает что страница не найдена. В чём может быть проблема?
    Ubuntu Server 14.04.1
    MySQL 5.5.37
    Zabbix 2.2.3
  • andreyussur
    • Jun 2014
    С MySQLем разобрался, вот его лог:
    140610 11:09:22 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-option$
    140610 11:09:22 [Note] Plugin 'FEDERATED' is disabled.
    140610 11:09:22 InnoDB: The InnoDB memory heap is disabled
    140610 11:09:22 InnoDB: Mutexes and rw_locks use GCC atomic builtins
    140610 11:09:22 InnoDB: Compressed tables use zlib 1.2.8
    140610 11:09:22 InnoDB: Using Linux native AIO
    140610 11:09:22 InnoDB: Initializing buffer pool, size = 128.0M
    140610 11:09:22 InnoDB: Completed initialization of buffer pool
    140610 11:09:22 InnoDB: highest supported file format is Barracuda.
    140610 11:09:22  InnoDB: Waiting for the background threads to start
    140610 11:09:23 InnoDB: 5.5.37 started; log sequence number 6324716
    140610 11:09:23 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
    140610 11:09:23 [Note]   - '127.0.0.1' resolves to '127.0.0.1';
    140610 11:09:23 [Note] Server socket created on IP: '127.0.0.1'.
    140610 11:09:23 [Note] Event Scheduler: Loaded 0 events
    140610 11:09:23 [Note] /usr/sbin/mysqld: ready for connections.
    Version: '5.5.37-0ubuntu0.14.04.1'  socket: '/var/run/mysqld/mysqld.sock'  port: 3306  (Ubuntu)
    • yukra
      • Apr 2013
      • 1359
      в настройках веб-сервера (в данном случае так понимаю апача).
      • andreyussur
        • Jun 2014
        А какие в нем настройки надо сделать?
        • bga83
          • Sep 2011
          • 268
          корректно прописать виртуальный хост, и по необходимости сделать автоматический редирект на /zabbix. Но все это не имеет отношения к настройкам непосредственно zabbix
          • andreyussur
            • Jun 2014
            Ок. Спасибо. Пойду гуглить.
