После обновления отсуствует легенда у Screens и Graphs
  • Artym
    • Nov 2015
    Здравствуйте!
    После очередного sudo apt-get update && sudo apt-get upgrade пропала легенда у Screens и Graphs
    Логи ниже.
    Спасибо.
    xxx@xxx:~$ lsb_release -a
    No LSB modules are available.
    Distributor ID: Ubuntu
    Description: Ubuntu 18.04.2 LTS
    Release: 18.04
    Codename: bionic
    cat /var/log/apt/history.log
    Start-Date: 2019-05-28 23:25:25
    Commandline: apt-get upgrade
    Requested-By: xxx (1000)
    Upgrade:
    netplan.io:amd64 (0.96-0ubuntu0.18.04.4, 0.97-0ubuntu1~18.04.1),
    cloud-init:amd64 (18.5-45-g3554ffe8-0ubuntu1~18.04.1, 19.1-1-gbaa47854-0ubuntu1~18.04.1),
    python3-software-properties:amd64 (0.96.24.32.7, 0.96.24.32.8),
    zabbix-agent:amd64 (1:4.0.7-1+bionic, 1:4.0.8-1+bionic),
    mdadm:amd64 (4.1~rc1-3~ubuntu18.04.1, 4.1~rc1-3~ubuntu18.04.2),
    initramfs-tools-bin:amd64 (0.130ubuntu3.7, 0.130ubuntu3.8),
    nplan:amd64 (0.96-0ubuntu0.18.04.4, 0.97-0ubuntu1~18.04.1),
    zabbix-server-mysql:amd64 (1:4.0.7-1+bionic, 1:4.0.8-1+bionic),
    python3-distupgrade:amd64 (1:18.04.32, 1:18.04.33),
    ubuntu-release-upgrader-core:amd64 (1:18.04.32, 1:18.04.33),
    grafana:amd64 (6.1.6, 6.2.1),
    zabbix-get:amd64 (1:4.0.7-1+bionic, 1:4.0.8-1+bionic),
    zabbix-frontend-php:amd64 (1:4.0.7-1+bionic, 1:4.0.8-1+bionic),
    initramfs-tools-core:amd64 (0.130ubuntu3.7, 0.130ubuntu3.8),
    initramfs-tools:amd64 (0.130ubuntu3.7, 0.130ubuntu3.8),
    software-properties-common:amd64 (0.96.24.32.7, 0.96.24.32.8)
    End-Date: 2019-05-28 23:26:02
    xx@xxx:~$ zabbix_server --version
    zabbix_server (Zabbix) 4.0.8
    Revision 2b50c941de 27 May 2019, compilation time: May 28 2019 09:22:06
    Copyright (C) 2019 Zabbix SIA
    License GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/gpl.html>.
    This is free software: you are free to change and redistribute it according to
    the license. There is NO WARRANTY, to the extent permitted by law.
    This product includes software developed by the OpenSSL Project
    for use in the OpenSSL Toolkit (http://www.openssl.org/).
    Compiled with OpenSSL 1.1.0g 2 Nov 2017
    Running with OpenSSL 1.1.0g 2 Nov 2017
    xxx@xxx:~$ sudo ls -all /usr/share/zabbix/fonts
    total 20
    drwxr-xr-x 2 root root 4096 Mar 10 10:33 .
    drwxr-xr-x 12 root root 16384 May 28 23:25 ..
    lrwxrwxrwx 1 root root 38 Mar 10 10:33 graphfont.ttf -> /etc/alternatives/zabbix-frontend-font
    xxx@xxx:~$ ls -l /usr/share/zabbix/fonts/graphfont.ttf /etc/alternatives/zabbix-frontend-font
    lrwxrwxrwx 1 root root 47 Mar 10 10:33 /etc/alternatives/zabbix-frontend-font -> /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf
    lrwxrwxrwx 1 root root 38 Mar 10 10:33 /usr/share/zabbix/fonts/graphfont.ttf -> /etc/alternatives/zabbix-frontend-font
  • Kozik
    • Oct 2016
    • 22
    Видимо нет файла /usr/share/zabbix/assets/fonts/graphfont.ttf, я скопировал его отсюда /usr/share/zabbix/fonts
    • Artym
      • Nov 2015
      Спасибо, помогло, хотя я ходил вокруг, да около этого файла. И не увидел. Выше лог приводил.
      Сделал для проверки прямо в лоб, хоть и неправильно, заработало.
      sudo cp /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf /usr/share/zabbix/assets/fonts/graphfont.ttf
      sudo chown -R www-data:www-data /usr/share/zabbix/assets/
      sudo systemctl restart apache2
