Zabbix2.4.3+ syslog-ng мониторринг Cisco как?
  • kamelotnsk
    • Jun 2014
    Мои настройки сервера.
    zabbix_server.conf
    ListenPort=10051
    SourceIP=172.17.100.72
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=0
    PidFile=/var/run/zabbix/zabbix_server.pid
    DBHost=localhost
    DBName=zabbix
    DBUser=zabbix
    DBPassword=zabbix234092234234234234
    DBSocket=/var/lib/mysql/mysql.sock
    StartPollers=5
    StartIPMIPollers=2
    StartTrappers=5
    StartPingers=1
    StartDiscoverers=3
    StartTimers=1
    VMwareCacheSize=8M
    SNMPTrapperFile=/var/log/snmptt/snmptt.log
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    zabbix_agent.conf
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    LogFile=/var/log/zabbix/zabbix_agentd.log
    LogFileSize=0
    DebugLevel=1
    Server=172.17.100.72
    ServerActive=127.0.0.1
    Hostname=Zabbix server
    Include=/etc/zabbix/zabbix_agentd.d/
    syslog-ng.conf
    @version:3.2
    options {
            flush_lines (0);
            time_reopen (10);
            log_fifo_size (1000);
            long_hostnames (off);
            use_dns (no);
            use_fqdn (no);
            create_dirs (no);
            keep_hostname (yes);
    source s_sys {
            file ("/proc/kmsg" program_override("kernel: "));
            unix-stream ("/dev/log");
            internal();
    destination d_cons { file("/dev/console"); };
    destination d_mesg { file("/var/log/messages"); };
    destination d_auth { file("/var/log/secure"); };
    destination d_mail { file("/var/log/maillog" flush_lines(10)); };
    destination d_spol { file("/var/log/spooler"); };
    destination d_boot { file("/var/log/boot.log"); };
    destination d_cron { file("/var/log/cron"); };
    destination d_kern { file("/var/log/kern"); };
    destination d_mlal { usertty("*"); };
    filter f_kernel     { facility(kern); };
    filter f_default    { level(info..emerg) and
                            not (facility(mail)
                            or facility(authpriv)
                            or facility(cron)); };
    filter f_auth       { facility(authpriv); };
    filter f_mail       { facility(mail); };
    filter f_emergency  { level(emerg); };
    filter f_news       { facility(uucp) or
                            (facility(news)
                            and level(crit..emerg)); };
    filter f_boot   { facility(local7); };
    filter f_cron   { facility(cron); };
    log { source(s_sys); filter(f_kernel); destination(d_kern); };
    log { source(s_sys); filter(f_default); destination(d_mesg); };
    log { source(s_sys); filter(f_auth); destination(d_auth); };
    log { source(s_sys); filter(f_mail); destination(d_mail); };
    log { source(s_sys); filter(f_emergency); destination(d_mlal); };
    log { source(s_sys); filter(f_news); destination(d_spol); };
    log { source(s_sys); filter(f_boot); destination(d_boot); };
    log { source(s_sys); filter(f_cron); destination(d_cron); };
    source s_netcisco {
    udp(ip(0.0.0.0) port(514));
    filter f_netcisco {host("172.17.2.139")
    or host ("172.17.3.1")
    or host ("172.17.3.2")
    destination df_netcisco {
    file("/var/log/hosts/$HOST-$LEVEL.log");
    log{ source (s_netcisco);
    filter (f_netcisco);
    destination (df_netcisco);
    Логи успешно падают /var/log/hosts/172.17.2.139-info.log
    Jan 17 17:46:59 172.17.2.139 %AAA-I-CONNECT: User CLI session for user i.ramer over ssh , source 172.17.100.176 destination  172.17.2.139 ACCEPTED
    Jan 17 17:57:02 172.17.2.139 %AAA-I-DISCONNECT: User CLI session for user i.ramer over ssh , source 172.17.100.176 destination  172.17.2.139  TERMINATED. The Telnet/SSH session may stll be connected.
    Создаю Элемент Данных:
    В итоге, в обзоре данные не появляются. Подскажите где ошибка?
  • kamelotnsk
    • Jun 2014
    Откатился на версию 2.4.0 данный функционал заработал.
