Скрипт python для обработки cisco traps
  • Chai
    • Aug 2020
    Есть известный скрипт cisco-psec-traphandler.py , с помощью которого производится обработка "сырого" сообщения с устройства cisco. Вот его начало.
    PHP Code:
    import sysosresubprocess
    import logging
    .handlersshlex
    from pysnmp
    .hlapi import *
    from configparser import ConfigParser
    from ipaddress import IPv4Address
    AddressValueError
    from pyzabbix import ZabbixAPI
    def read_config
    (filenamesection):
    """ Read a configuration file and return a dictionary object
    aram filename: name of the configuration file
    aram section: section of a configuration
    :return: a dictionary of a configfile section parameters
    # create parser and read ini configuration file
    parser ConfigParser()
    parser.read(filename)
    # get section
    db = {}
    if
    parser.has_section(section):
    items parser.items(section)
    for
    item in items:
    db[item[0]] = item[1]
    else:
    raise Exception('{0} not found in the {1} file'.format(sectionfilename))
    return
    db
    def find_ifDesc_from_ifIndex
    (hostnameifIndexcommunity="public"):
    errorIndicationerrorStatuserrorIndexvarBinds next(
    getCmd(SnmpEngine(),
    CommunityData(community),
    UdpTransportTarget((hostname161)),
    ContextData(),
    ObjectType(ObjectIdentity('IF-MIB''ifDescr'ifIndex)))
    if
    errorIndication:
    logging.error(errorIndication)
    elif errorStatus:
    logging.error('%s at %s'errorStatus.prettyPrint(), errorIndex and varBinds[int(errorIndex) - 1][0] or '?')
    exit(
    1)
    else:
    ifDescr varBinds[0][1].prettyPrint()
    return
    ifDescr
    # find the path where the script is located to find a config.ini nearby
    dir_path os.path.dirname(os.path.realpath(__file__))
    conf_file_name dir_path '/config.ini'
    # fetch config parameters
    snmp_config read_config(conf_file_namesection 'snmp')
    api_config read_config(conf_file_namesection 'api')
    logging_config read_config(conf_file_namesection 'logging')
    zabbix_config read_config(conf_file_namesection='zabbix')
    #db_config = read_config(section = 'mysql')
    # set logging handler
    handler logging.handlers.WatchedFileHandler(os.environ.get ("LOGFILE"logging_config['logfile']))
    #formatter = logging.Formatter(logging.BASIC_FORMAT)
    formatter logging.Formatter'%(asctime)s - %(name)s - %(levelname)s - %(message)s')
    handler.setFormatter(formatter)
    root logging.getLogger()
    root.setLevel(os.environ.get("LOGLEVEL"logging_config['loglevel']))
    root.addHandler(handler)
    # now parse the stdin
    inp sys.stdin
    # the first line is alwats hostname
    hostname inp.readline().strip()
    # the second line contains an IP address that should be fetched by regexp
    trapstr inp.readline()
    re.search("\[(.*)\]:[0-9]+->"trapstr)
    ip m.group(1
    Не могу понять, откуда берется вводная часть для обработки
    inp = sys.stdin
    Это вроде как стандартный ввод , по-умолчанию, с клавиатуры. Но мы же не с клавиатуры получаем материал, а как говорит теория, согласно настройке config.ini парится лог
    logfile = /var/log/cisco-errdisable-traphandler.log
    Но несмотря на то, что из сети идет много трапов, время последнего изменения этого файла - несколько дней назад.
    Объясните, пожалуйста, что за ввод со стандартного ввода имеется здесь в виду?
  • Navoyenok
    • Dec 2011
    • 101
    Доброе утро! Если быть точнее, то это не стандартный ввод, а стандартный поток ввода. Так вот при запуске этого скрипта, в стандартный поток ввода будут сохранены 7 строк данных: hostname, ip, uptime, oid, address, community, enterprise. Так что всё верно не переживайте.
    • Chai
      • Aug 2020
      Спасибо за ответ!
      Я не просто так "переживаю", пытаюсь понять механизм обработки трапов на нашем сервере. На нем настроена обработка трапов для сетевых устройств семейства Cisco, а еще нам всучили huawei, а вот продукцию этого вендора в части трапов не поддерживается в этом скрипте.
      в zabbix_server.conf есть две строки для указания хранения трапов (оба они содержат или не все фактически случившиеся события или вообще не обновляются с 20-го года)
      SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
      StartSNMPTrapper=1
      SNMPTrapperFile=/var/zabbix_traps.tmp
      Сотрудник, который устанавливал заббикс, здесь уже не работает, да и ничего уже не помнит.
      Поэтому мне надо понять этот механизм, чтобы попробовать переписать скрипт для дополнения функционала или добавить на него основе другой.
      В инструкции написано
      Для чтения трапов, Zabbix сервер или прокси должны быть настроены на запуск процесса SNMP траппера и должны знать абсолютный путь к файлу с трапами, который заполняется при помощи SNMPTT или получателя трапов Perl. Чтобы это сделать, измените файл конфигурации (zabbix_server.conf или zabbix_proxy.conf):
      1. StartSNMPTrapper=1
      2. SNMPTrapperFile=[ФАЙЛ С ТРАПАМИ]
      3. ...
      4. https://www.zabbix.com/documentation...types/snmptrap
      Чтобы запарсить массив сообщения от huawei, мне нужно определить, в каком виде он приходит на вход скрипта.
      Чтобы кто-то приручал тарпы huawei, я не нашел в интернете и у производителя.
      • Chai
        • Aug 2020
        Еще вопрос
        config.ini в /external-scripts имеет настройки:
        trapkeyname = ErrDisabled
        trapkeyname_disable = ErrDisable
        trapkeyname_restrict = ErrRestrict
        [logging]
        loglevel = INFO
        Что в нем писать, если добавлять huawei?
