Установка Zabbix-agent Ошибка Depends libmodbus5 (>= 3.0.2) but it is not installable
  • D.Frolov
    • Apr 2020
    • 95
    1. cat /etc/os-release
    PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
    NAME="Debian GNU/Linux"
    VERSION_ID="12"
    VERSION="12 (bookworm)"
    VERSION_CODENAME=bookworm
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    2. https://www.zabbix.com/ru/download?z...debian&os_vers ion=12&components=agent&db=&ws=
    3. apt install zabbix-agent
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
     zabbix-agent : Depends: libmodbus5 (>= 3.0.2) but it is not installable
    E: Unable to correct problems, you have held broken packages.
  • Kos
    • Aug 2015
    • 3469
    Первый шаг этой инструкции (установка пакета репозитория) до этого выполнен?
    wget https://repo.zabbix.com/zabbix/6.0/debian/pool/main/z/zabbix-release/zabbix-release_latest+12_all.deb
    dpkg -i zabbix-release_latest+12_all.deb
    apt update
    • D.Frolov
      • Apr 2020
      • 95
      apt update
      Да, конечно выполнена
      • D.Frolov
        • Apr 2020
        • 95
        apt update
        Вы выбираете агента 2, там вообще ответ 404
        --2024-10-15 16:54:31--  https://repo.zabbix.com/zabbix/6.0/debian/pool/main/z/zabbix-release/zabbix-release_latest+12_all.deb
        Resolving repo.zabbix.com (repo.zabbix.com)... 178.128.6.101, 2604:a880:2:d0::2062:d001
        Connecting to repo.zabbix.com (repo.zabbix.com)|178.128.6.101|:443... connected.
        HTTP request sent, awaiting response... 404 Not Found
        А вот когда Agent просто, то да, все установлено
        • Kos
          • Aug 2015
          • 3469
          Я что ни выбираю, там высвечивается одна и та же ссылка. Но Вы правы - она на данный момент битая, правильная - такая:
          https://repo.zabbix.com/zabbix/6.0/debian/pool/main/z/zabbix-release/zabbix-release_latest+debian12_all.deb
          Написал, чтобы поправили.
          • D.Frolov
            • Apr 2020
            • 95
            VERSION_ID="12"
            ID=debian
            Проблема решилась, вот что было:
            1. Это был сервер Proxmox Backup Server
            2. По умолчанию, там платный репозиторий, не давал сделать apt update && apt upgrade
            3. Заменил, на бесплатный репозиторий, сделал apt update && apt upgrade
            4. Смог установить zabbix-agent проблем не возникло.
