I Have been trying to install the version 1.4 and 1.6 but always get the same mistake, at the end I get an error message indicating that the database is corrupted and has not found the users table. When I review the structure of the database It always has no tables always it's empty. What can I do or what are the proper installation step ?. Thanks a lot any help
problem installing zabbix
Hi!Have you followed the Manual instructions?
You probably skipped the DB population scripts.
Try these:
http://ubuntuforums.org/
archive/index.php/t-1169394.html
http://www.zabbix.com/forum/showthread.php?t=13391
Do you know Other manual install Zabbix on CentOS 5.
Zabbix for used a vps, this is a problem?Comment
