Documentation not updated
  • CharlieRoot
    • Oct 2020
    • 15
    Working with the Event Tags we found that documentation has not been updated for 5.x.
    Looking at the documentation here:
    Zabbix (5.2.1) show only one field named "Tag for matching". What is the required syntax for this field?
  • CharlieRoot
    • Oct 2020
    • 15
    Originally posted by cyber
    IIRC you should enter a tag name there, what you are going to use for matching. Tag values match, you succeed..
    So i can't use multiple tag names and/or their values?
    • CharlieRoot
      • Oct 2020
      • 15
      Not that I know of... as long as I remember that "OK event closes All problems if tag values match " has always been with one tag only.
      Then why in the (older) documentation does it shows more fields to match on, including values.. ?
      • CharlieRoot
        • Oct 2020
        • 15
        ok.. Seems you are right, I did not check docs so far back... there has been multiple tag options in 3.2-4.0, but starting from 4.2 pic in documentation shows (and reality confirms), there is just one tag to match...
        But then docs are showing exactly, how reality is and was... Missing is maybe a (release) note, why multiple tag option was dropped...
        Please point me to the documentation where you find this
          • 4993
          EDIT: My posts here are out of sequence due to human error and restoring of posts, try to fit them between other posts in thread, you should get a bit more clear picture.
            • 4993
              • 4993
                • 4993
                https://www.zabbix.com/documentation...iggers/trigger
                Change the version in upper row and look at that first pic
